Any UK/Europe based full lathe set ups for sale?
status66uk
Post: # 51527Unread post status66uk
Sun Oct 14, 2018 11:10 am
Im looking to get back in to cutting, I used to own a customised VR but i sold it as i could never get speed stability with the deck i used and had a lot of swarf issues when trying to cut Longer LP sides, Which is mainly what i want the lathe for, would possibly consider a VR again if an SP10 was included with it,
Will consider anything as long as its a full set up and in full working order and the set up is proven to be able to cut long LP sides fairly consistantly when used properly.
Jay Diggins
Re: Any UK/Europe based full lathe set ups for sale?
Post: # 51551Unread post Jay Diggins
Tue Oct 16, 2018 10:38 am
Just to say that I have a customized VR....and use a Garrard 401 in a really heavy plinth. It is rock solid and sounds superb. It took quite a lot of effort to get the VR to fit over the Garrard, but well worth it in my opinion.
It sounds obvious but I think one will have problems with swarf on all lathes if the vac pipe is not carefully put in the correct position. A bit of trial and error is needed but I moved mine closer to the cutterhead and the vinyl and that solved all the problems.
Happy cutting :-)
status66uk
Post: # 51567Unread post status66uk
Wed Oct 17, 2018 1:25 pm
Thanks for your reply
I was more bothered about the pitch issues than the swarf issue, if i could have got the speed to be perfectly steady with very little wow and flutter i would have sorted the swarf issue next but i ran out of patience and most people said i needed to be using an SP10 to get rid of the issue, I was using a Numark TTX deck
himynameisjacob
Post: # 51568Unread post himynameisjacob
Wed Oct 17, 2018 2:02 pm
Hi there. I have couple of lathes for sale, but oldies...
