Fantastic heat lamp, no warping, quick for sale!
David34
Post: # 62509Unread post David34
Sat Mar 04, 2023 5:10 pm
I have decided that I’m going to sell these setups, plus adjustable hook.
Since I’ve started using this setup, and got rid of side lights, my discs are heated in minutes and evenly.
Get to heats of 51c in minutes without warping as this spreads the heat evenly.
Best thing I ever did.
$70 + postage. Gives you the full kit. Fully adjustable.
Note - you will need to drill into ceiling batton. This should be done by a professional due to power, correct installations. You may need an electrician to create a PowerPoint also, Australia plug, but we can convert (at cost)
David34
Re: Fantastic heat lamp, no warping, quick for sale!
Post: # 62520Unread post David34
Tue Mar 07, 2023 3:43 am
Why didn't photo work?
