K8 with 1d and Jed stepper FS
apoklis
Post: # 63036Unread post apoklis
Tue Jun 20, 2023 1:44 pm
Feeling left out? Wanting a lathe but can't afford a neumann lathe? Well I have a deal for you. For probably less then the price of the platter,a Presto K8 for sale comes with Jeds stepper motor and original belt. The original belt doesn’t sound bad but the stepper motor has less wow. It also has a 1D instead of a 5C and sounds good. Has a 45 adapter if you decided to use original motor. The tubes are good, amps good. You may want to recap the amp. Includes original playback tone arm as well as a cheapo I stuck on there. Cheapo needs needle but works. Stand 112 LPI inside and out. Has in line fuse for head added and there are ten 500 milliamp replacement fuses with it.
PM me for questions and price. I’m in St. Louis Missouri and prefer local pick up. I could deliver in the Midwest. We could discuss shipping but these are very heavy. With local pickup I could show you how to use it so you could make records before you leave. I can throw in a good used sapphire cone stylus and your first ten 7 inch polycarb disks.
look better if you click on pic Al apoklis
