Hello trollers, I have a question, do you know a supplier that can realize a stamper in order to have relief graphic on the blank side?
I would like to make a record like this instead classic etching.
Re: Relief graphic on blank vinyl side
I would think you could get your design cut into a self adhesive vinyl sheet, stick it onto a lacquer disc and plate it. This assumes the silver spray will adhere to the vinyl sticker.
Anyone who makes stampers can do this if they don't mind some experimentation.
Re: Relief graphic on blank side of vinyl record
Maybe UV ink could work too?
I thought to print the reverse image with UV plotter and then make the standard galvano process.
Anyone have done something like that?
