Drive wheels Rebuild
Links to helpful record-lathe-oriented services (repair, equipment) and their websites.
Doug6N
Post: # 2296Unread post Doug6N
Thu Feb 14, 2008 11:40 pm
Hi:
I just got a set of drive wheels for my 6N back from Terry's Rubber Rollers. Absolutely flawless and beautiful. :) Quiet as a church mouse.
I recomend him highly. :)
Doug
JayDC
Post: # 2298Unread post JayDC
Fri Feb 15, 2008 5:06 am
can you drop a link or number, and maybe a price?.. what was his turn around time?
Viewmaster
Post: # 2299Unread post Viewmaster
Fri Feb 15, 2008 6:35 am
Just Goggle the name. Comes up No1 on Google .
Albert.
Simon
Post: # 2424Unread post Simon
Thu Mar 13, 2008 4:38 pm
emorritt
Post: # 6720Unread post emorritt
Sun Nov 15, 2009 10:53 am
I've used Terry before also, with excellent results for both turntable idlers as well as tape machine parts. A few years ago the only place I knew of that was doing this kind of work was Russell Industries. I'd sent my 6N idlers to them and discovered when they came back they'd simply ground off an amount of the existing rubber, then molded new to the old. You could see where the old ended and the new began, and they weren't exactly 'true' either, making some very slight noise and creeping up the idler shaft when in operation. When I found his website, I sent the same idlers to Terry and when I got them back they looked factory new. Same goes for tape machine parts. Can't recommend him enough.
