Rejuvinating Disc Records 1967 article-Broadcast Engineering
Simon
Post: # 2677Unread post Simon
Tue Apr 29, 2008 5:43 am
Great find
harper
Post: # 2680Unread post harper
Tue Apr 29, 2008 11:31 am
Figured this would be helpful for those who are trying to restore these suckers and new to everything. Download and print this out.
jacques artifex
Post: # 2685Unread post jacques artifex
Wed Apr 30, 2008 10:22 am
Very good, Thanks.
In cut we trust
JayDC
Post: # 2695Unread post JayDC
Thu May 01, 2008 4:41 am
Here are some test tone I made for all of yous..
It's a zip archive, inside are 4 test tones in wav format (16bit/44.1K).
These should help with calibration.
1. Sine wave sweeping up from 1Khz to 10Khz - 1 minute 40 seconds duration
2. Sine wave sweeping down from 1Khz to 50Hz - 1 minute 40 seconds duration
3. Pink Noise - 1 minute 40 seconds duration
4. White Noise - 1 minute 40 seconds duration
http://www.sendspace.com/pro/dl/wopnp3
studiorp
Post: # 2697Unread post studiorp
Thu May 01, 2008 6:07 am
I have written these files on a cd, many interesting, but which is the function of these frequences ?
What can I calibrate ?
Thanks.
JayDC
Post: # 2702Unread post JayDC
Thu May 01, 2008 12:37 pm
use these to set your EQ... Cut them to record, and play back through an osciloscope, or frequency analyzer. Compare with the ones on the cd, and make adjustments until they are very close to matching.
studiorp
Post: # 2703Unread post studiorp
Thu May 01, 2008 1:13 pm
Ok, but these values correspond to an inverse curve riaa perhaps ?
JayDC
Post: # 2704Unread post JayDC
Thu May 01, 2008 1:51 pm
no, send these through the riaa curve.
Playback the tones on acetate through a turntable hooked up to a turntable preamp. compare the tones (on disc with inverse riaa, then through riaa premap) to the originals (no riaa). They should be about the same. if not, adjust the EQ until they are the same..
These are the tones mentioned in the article above..
this process can take very many cuts..
