Dr Dub cuts on Laserdisc
drdub
Post: # 53248Unread post drdub
Wed May 29, 2019 4:38 pm
Hello mates,
We experimented a little bit with laserdiscs in the past few days. Maybe it's interesting for you guys;)
We got pretty good results with preheating the discs to 45-50° and using more stylus heating than for vinyl. We used a diamond stylus for it.
Does anybody know how durable these laserdiscs will be? How many times can they be played?
best regards,
Dub
*** www.drdub.com ***
edaudio
Re: Dr Dub cuts on Laserdisc
Post: # 53274Unread post edaudio
Sun Jun 02, 2019 1:20 pm
I have only embossed on polycarbonate (CD/DVD blanks) with a very old RCA mono head. What progress I've made seemed to point toward using a standard cutting stylus but in reverse (not cutting but embossing). I haven't really experimented with heat, because that type of cutting stylus has very little room to put a few turns of nichrome.
I had looked into diamond stylus - I would think that last generation of Neumann DMM systems would be well suited to cutting into polycarbonate, which is a very robust plastic.
That said, my short term focus has been on creating proper record electronics and rewinding the head coil and adding a ceramic element for feedback.
Also, while there is not shortage of CD and DVD blanks, I am very excited about the PVC blanks. My first test - cutting PVC - was sooo much better than embossing polycarbonate, that I am persuing that path for the time being, which means setting up a vacuum system for the chip.
one-percent inspiration and 99% perspiration
