Van Eps eccentric leadout cutter US Patent
EmAtChapterV
Post: # 23673Unread post EmAtChapterV
Tue Feb 26, 2013 12:55 am
From an Ebay auction, the name Van Eps rang a bell, and I discovered I could search US patents by name... and I found this:
http://www.google.com/patents?id=nChpAAAAEBAJ&pg=PA1&dq=us+patents+van+eps&source=gbs_selected_pages&cad=2
I wonder if someone could build one of these from scratch? I've tried doing eccentric lock grooves using a worn cutting stylus trimmed down and wedged into a craft circle cutter on a variable speed Lenco turntable, but my success rate is only 50 percent, and noisy when it does work.
Re: Van Eps eccentric leadout cutter US Patent
Post: # 23700Unread post Aussie0zborn
Tue Feb 26, 2013 5:07 pm
Why would you want to cut an eccentric locked groove?
Angus McCarthy
Post: # 23719Unread post Angus McCarthy
Wed Feb 27, 2013 2:44 pm
To re-create the old Victrola runout groove that would trigger their return mechanism, of course.
