Serif
Neumann EEq schematic?
Post: # 15255Unread post Serif
Wed Jun 08, 2011 7:54 am
Looking for the schematic for a Neumann elliptical eq.
Anyone tried the Avenson Mid/Side for this purpose?
http://avensonaudio.com/mid-side/
Thanks,
Andrew
gold
Post: # 15263Unread post gold
Wed Jun 08, 2011 4:49 pm
Which one? EE66/70 or EE77.
Serif
Post: # 15264Unread post Serif
Wed Jun 08, 2011 6:59 pm
Either 66 or 70 would be great. Does either one use an actual Cauer filter for the Side channel h/p? That equiripple setting looks like it might help in a pinch. (;
Thanks,
Andrew
gold
Post: # 15280Unread post gold
Thu Jun 09, 2011 2:10 pm
The EE66 and EE70 are the same circuit. The EE70 was just a new board layout. This one uses an inductor in the crossover so is not not really suitable for cloning.
I had a board laid out for the EE77. The circuit is the same but there are some improvements. The FET switching was removed. I'm using a rotary switch. All the quad opamps were replaced with singles and there are THAT 1246/1646 line driver and receivers (which can be bypassed). If you want one let me know. I can make a unit but I'm not selling boards. I spent a lot having the boards laid out and can't sell them cheap.
I have the EE77 in a PDF. It's two pages that aren't joined together. I'm not sure if I can upload the file to this board.
andybee
Post: # 15282Unread post andybee
Thu Jun 09, 2011 4:43 pm
yes, gold is right, the earlier versions have a special inductor,
if you are experienced in coil winding, no problem....
like to see the EE77 also :)
please send me email or PM, I can upload it for the board.
update:
www.mastercut.eu/c/Neumann_EE77.pdf
can´t find the EE66 schematics anymore...
Post: # 15319Unread post opcode66
Sun Jun 12, 2011 7:08 am
EE70 Schematic
High resolution Bitmap available here:
http://www.deepgroovesmastering.com/images/trolls/ee70/Neumann_EE70_Schematic.bmp
audadvnc
Post: # 19523Unread post audadvnc
Sun May 06, 2012 7:20 pm
I suspect you could swap in a 10H inductor for the one in that Neumann schematic; the impedances look about right. I'm planning to build a passive version of this circuit to throw across my inputs when needed.
