Various Scully/Westrex/Capps stuff
yep.
Moderators: piaptk, mossboss, Aussie0zborn, tragwag, Steve E., Simon
Unread postby Virtalahde » Sat Apr 27, 2013 1:52 pm
I have a ton of papers and drawing that came along with my Scully. It's quite a bit of an effort to scan all of it, so let's try it the other way around:
Is there anything in particular you're missing?
Virtalahde
Re: Various Scully/Westrex/Capps stuff
Unread postby Steve E. » Sun Apr 28, 2013 8:34 pm
Anything on the qualities of pre-1948, "standard groove" styli from Capps? really, any Capps styli info might be interesting!!!
Steve E.
Site Admin
Blog: View Blog (14)
Unread postby Serif » Sun Apr 28, 2013 9:34 pm
Cappscoop! Styli in the shape of a cat's claw.
- Serif
Serif
Unread postby Virtalahde » Mon Apr 29, 2013 1:44 am
I think I only have the pitch computer related stuff, but I'll have a look, there's a file full of brochures, too. I think I'll also list here what I have. One thing I've already been requested is the Scully pitch/depth system, and they're coming up.
Virtalahde
Unread postby Virtalahde » Tue Apr 30, 2013 11:46 am
Here's some of the stuff I have:
-Capps Vari-Pitch, full installation guide + schematics
-Scully type 261-C variable feed unit schematic
-Scully variable depth unit (transistorized) schematic, dated 11/3/60
-Scully carriage junction box schematic
-Scully push-button panel schematic, S/N sub. 560
-Scully sequence panel with banding unit schematic
-Scully relay box wiring for single phase motors
-Scully relay control panel schematic, dated 7/9/59
-Scully aluminium base wiring
-Westrex 3DII + 1700A schematics (the later model)
-Schematics + documentation for the op-amp based Westrex constant velocity EQ's
-Some documentation for setting up the 3DII recorder, seems pretty rare
And the real treat is this: Full file of Scully recording machine. Including:
-Electrical circuit details (schematics and detailed description of the action taken by each function)
-Black & white photos of the Scully lathe with number indexing
The latter is referenced to a complete set-up guide with topics:
SCULLY DISC RECORDING MACHINE
INSTALLATION AND ADJUSTMENTS
1. Machine set-up
2. Ending line adjustment
3. Lead-in line adjustment
4. Cutter drop and tape start adjustments
5. Operation of machine
6. Belt adjustments
7. Intermediate yoke thrust adjustment
8. Turntable shaft bearing adjustments
9. Feed screw thrust adjustment
10. Feed nut adjustment
11. Variable feed idler pressure
12. 8 and 32 pitch solenoid adjustment
13. Cutter saddle adjustments
14. Vacuum turntable
15. Speed changes
16. Feed ranges
17. Lubrication
Is there any interest for the whole manual? Seems like it covers everything to me.
EDIT: I now realize this topic really should be in the circuits/schematics/manuals subforum. I'll post my scans there.
Virtalahde
Unread postby opcode66 » Tue Apr 30, 2013 3:54 pm
I'm interested in:
Groove Graphics, VMS Halfnuts, MIDI Automation, 320 Diamondsi & Stereo Feedback Cutterheads Soon!
Cutterhead Repair: Recoiling, Rewiring, Cleaning, Cloning of Screws, Dampers & More.
www.DeepGroovesMastering.com
Blog: View Blog (2)
Unread postby skyonion » Mon May 06, 2013 6:28 pm
Hi Jaakko,
I'm could use:
Eventually I'm going to try and get my variable feed unit running and I don't have much documentation on it. The schematic would be very helpful.
skyonion
Unread postby Virtalahde » Tue May 07, 2013 3:46 am
I'm on it. I'll need to figure out how to scan it all, but trust me, I'll get there.
The schematics are pretty big sheets of paper.. I'll try to take a photo.
Virtalahde
Unread postby opcode66 » Tue May 07, 2013 3:10 pm
To do this correctly you need to scan it in pieces and use something like photoshop to put the pieces together into one file. If you take a picture you'll have to back out far enough to get it all in frame. But, that will make it impossible to read fine details on the schamtic like the values of the components.
Blog: View Blog (2)
Unread postby Virtalahde » Tue May 07, 2013 3:26 pm
Could be. The large schematics are folded into A4 size, so scanning them should be easier when they're already divided in scannable chunks.
Virtalahde
Unread postby W.B. » Tue May 07, 2013 8:44 pm
I happen to be interested in the photos and:
Appears from the S/N you must have a Model 601. I always dug the lead-in and -out grooves emanating therefrom (the "8 and 32 pitch" which was a bit less on the former and a bit more on the latter).
W.B.
Unread postby Virtalahde » Wed May 08, 2013 1:57 am
Yes, it's a vary lathe model. My S/N is #644. The body of the machine says "501" in some parts (like the assembly holding the flywheel the turntable belts hook up to), but I assume this is because the molds have this same label.
My Scully is undergoing a strip-down. It was already partially torn down - first had a Capps computer installed, then gutted and the weirdest system ever was installed. A Linux computer hooked up to a motor controller. Now I'll be hooking up a new Pitch13 box from Flo.
Virtalahde
Unread postby W.B. » Wed May 08, 2013 5:42 am
Virtalahde wrote:Yes, it's a vary lathe model. My S/N is #644. The body of the machine says "501" in some parts (like the assembly holding the flywheel the turntable belts hook up to), but I assume this is because the molds have this same label.
The molds would indeed have dated to when the company was making the older Model 501's (with gearbox instead of pitch knob). The 601 which 'skyonion' has in his studio likewise has parts with 'Scully 501' molds.
W.B.
Unread postby Virtalahde » Wed May 08, 2013 6:08 am
Here's a shot I took today:
I'm trying to get it to the state that I can do "cold" test cuts with no audio by the end of this summer. Meaning TT, vacuum, heating and all that is working. The goal is to have it up and running by the summer of 2014.
Virtalahde
Unread postby tragwag » Wed May 08, 2013 4:51 pm
beautiful machine!
best of luck getting it running, it seems like you have the right idea and a lot of the technical info.
at Audio Geography Studios, Tallahassee, FL USA
Blog: View Blog (1)
Unread postby bancho » Thu May 09, 2013 5:43 pm
Looks great! :)
are you going to hook c37 with scully? (please do so :) )
bancho
Unread postby chris king » Thu Jun 13, 2013 6:46 am
Any info on Turntable shaft bearing adjustments
would be great ,pics very welcome of bearing set up
chris king
Unread postby ejemmons » Tue Aug 27, 2013 8:20 pm
I am quite interested in the skinny for the Scully 261-C Variable Pitch unit, if anyone has this it would be much appreciated. If not, stay tuned for I will draw it out myself and share it...
RA-1574E amps.
ejemmons
Unread postby chris king » Wed Sep 11, 2013 1:28 pm
CAN I HAVE ANYTHING ON THE CAPPS VARI GROOVE SYSTEM
chris king
Unread postby Maistrow » Wed Sep 11, 2013 6:56 pm
I would like something on the Capps Vari groove system also.
Thank you.
Maistrow
Next
Return to Circuits, schematics and manuals
Who is online
Users browsing this forum: No registered users and 2 guests
