Diamond Stylus Broken
Audiofiligram
Post: # 15625Unread post Audiofiligram
Mon Jun 27, 2011 5:01 pm
Hey Trolls ,
My Diamond Stylus is broken !!! , i didnt´even cut 30 min with this stylus , F**k !!! Some ideas why it broke after 30 min ???
It was a new one From Vinylium that i used with an SC -99 Head cutting
on Vinyl Blanks and Lexan Blanks .
Thx
flozki
Post: # 15626Unread post flozki
Mon Jun 27, 2011 5:17 pm
yes. happend to me a few times.
do you have cutter damping?
i normally had troubles with vinyl discs.
almost never with lexan.
and better use the once from steve or the once from vinylike.com
i use now the vinylike once but made tons of records with the vinylium stylus.
and in 95% it was my own mistake.
i use mostly with my disk-o-mat and in the beginning i had no damping.
when added and adjusted a little. stylus lasted much longer.
or for example droping the head when no blank was on the turntable..autsch...well its an automated lathe. so stuff like this hapened in the beginning...
also a few people on this forum use heated stylus. which until now. (on next generation vinylike i will use) i never used. only a lamp sometimes..
that should increase lifetime dramatically.
Post: # 15627Unread post opcode66
I've been told that if you aren't gentle about lowering the cutterhead this can happen. Letting the head fall down hard will cause damage and potentially weaken the diamond.
Is it actually chipped/broken via visual inspection. Or do you just have a lot of SHHHHHHHHHHHH in your latest cuts?
Audiofiligram
Post: # 15629Unread post Audiofiligram
Mon Jun 27, 2011 5:35 pm
On the mechanics of the Dubcutter there is damping , you
can adjust turning on a little knob for lowering , so maybe
the damping effect did not take place because i lowered to much
and the damp was too stretched !!! I don´t know ...
I inspected it , its broken in the middle of the cutting edge !!!
I remember i had lot of trouble to remove the shhhhhh , it was
a sign !!!
I saw there are some people selling Diamond Stylus ... which
diamond would be the best for cutting PVC and PC ?
Thanks Trolls
Audiofiligram
Post: # 15640Unread post Audiofiligram
Tue Jun 28, 2011 8:16 pm
I was told not to put too much weight on the SC - 99 head and to respect
90 degree cutting angle between Stylus and Blank , somebody got some
advice how to adjust this accuratly and which instrument I could use for this purpose !
I use the original Vinylium Dubcutter mechanics .
Thx Trolls
fraggle
Post: # 15642Unread post fraggle
Wed Jun 29, 2011 5:14 am
welcome to the club mate i broke 4 stylus in half a year. i cut maybe 25 records in total......
Audiofiligram
Post: # 15648Unread post Audiofiligram
Wed Jun 29, 2011 12:20 pm
Did you resolved the Problem ?
fraggle
Post: # 15658Unread post fraggle
Thu Jun 30, 2011 2:12 am
nah mate . i'm trying to cut my own stylus but that's just as hard...will update if i have any news.
andybee
Post: # 15659Unread post andybee
Thu Jun 30, 2011 8:53 am
yes, a damper is needed!
AND the MOST IMPORTANT THING:
the stylus must be mounted in the correct angle!!!
and, cutting angle must be 0degrees, everything
else destroys the stylus....
there are different sentiments about the cutting angle,
I think, it must be 0 degrees, perpendicular to the plate....
(I hope the words are good)
:D
fraggle
Post: # 15667Unread post fraggle
Thu Jun 30, 2011 7:36 pm
@flozki
any idea how to mount a damper on a dubcutter? do you have any photos of your damping system?
Cheers mate
carter
Post: # 16129Unread post carter
Tue Aug 09, 2011 9:16 am
I'm awaiting a new diamond for a dubcutter/sc-99and am concerned about the cutting angle - concerned because I don't understand how to make the angle 0 degrees. Where is this adjusted?
fraggle
Post: # 16131Unread post fraggle
Tue Aug 09, 2011 7:48 pm
The only way to adjust that is to raise the platter.
0 degrees is quite hard with the dubcutter. I raised the platter to get between 0-2 degrees or something.
carter
Post: # 16196Unread post carter
Tue Aug 16, 2011 12:57 pm
Fraggle,
Thanks your answer made me feel less stupid, because I concluded that was all I could do.
Has this method generally avoided problems with diamond/poly cuts?]
--Carter
Audiofiligram
Post: # 16276Unread post Audiofiligram
Mon Aug 29, 2011 2:57 pm
Ok I managed to lower the head !
So what i try is to release the spring so the head goes down and try to get this 90 degree to the plate , has anybody has suggestion how i can measure the angle with precision between diamond stylus and plate , which instrument do you use ?
Cheerz
d
Post: # 16277Unread post d
Mon Aug 29, 2011 4:16 pm
hey
i remember i have read in the red book about finding the right angle.
the aluminum tools were used. it has to be the height of a stylus with the conical shank as stylus and with a bar is couple of cm long. It should lay down on the plater and thats how you get 90 degrees.
i don't know if I am clear about it but if you have the book you will definitely find article about it. I haven tried it but will try to find some time to make it.
I think I will take aluminum bar in height of stone. drill the hole as close as I can to the stone dia. Then will insert the damaged stylus with glue and that would be quite good tool for adjusting.
regards
_______
Audiofiligram
Post: # 16404Unread post Audiofiligram
Wed Sep 14, 2011 1:43 am
Is this to find in the Volume 1 (Groove Geometry & Recording Process) ?
thx
d
Post: # 16405Unread post d
Wed Sep 14, 2011 1:46 am
yep. page 201
_______
Audiofiligram
Post: # 16542Unread post Audiofiligram
Sun Oct 02, 2011 3:51 pm
Thx Throlls !!!!
slumpcutter
Post: # 20028Unread post slumpcutter
Thu Jun 07, 2012 7:13 pm
So, Audiofiligram, did you ever achieve a better cutting angle? How are the cuts turning out?
jjgolden
Vinylium Diamond stylus / sx74?
Post: # 21464Unread post jjgolden
Wed Oct 17, 2012 6:25 pm
Has anybody used the Vinylium diamond stylus to cut lacquer masters using a vms/sx74?
http://www.vinylium.ch/page/content/index.asp?MenuID=25&ID=23&Menu=1&Item=10.2
JJG
