Record Lathe Question:45 lathe?
This is a special section, perhaps temporary, to help our man Timmy1 with his efforts to assemble a working 8J10 Wilcox-Gay Recordette for experimental record cutting. The reasons for this will be explained shortly, but please do check in and help! He's a great guy with a worthy project.
timmy1
Re: Record Lathe Question:45 lathe?
Post: # 23047Unread post timmy1
Fri Feb 01, 2013 8:37 pm
Angus McCarthy wrote:Oh, you mean a Dictation Machine.
Well, assuming you can find a model with a spindle that would let you fit a CD, and as long as you have a good embossing stylus, it should be quite possible.
On a wilcox gay recordette can you modify them to record at 45 speed?
Angus McCarthy
Post: # 23048Unread post Angus McCarthy
Fri Feb 01, 2013 8:49 pm
I'm not sure about the Recordette, but on my Recordio there is a way to reduce the platter speed from 78rpm down to about 38rpm.
Remove the platter and you should see the drive assembly. (I don't know if it's the same on a Recordette but it's probably pretty close) The drive shaft/capstan has a collar attached to it. Loosen the set screw and remove the collar. This should lower the speed of the platter to near 38rpm. Then, when you record onto your disc, slow down your source audio by 84.4% and it will play back at 45rpm!
timmy1
Post: # 23049Unread post timmy1
Fri Feb 01, 2013 9:40 pm
Thank you when I get the lathe I want to try recording on solo picnic plates with a fine needle and see how it will play on a 45 record player.
Steve E.
Site Admin
Post: # 23052Unread post Steve E.
Sat Feb 02, 2013 2:01 am
Tim, this thread on a different board mentions a wilcox-gay recordette that was three speed! I don't know if that is true of the one you are buying. unfortunately nobody mentions a model number here.
http://www.antiqueradios.com/forums/viewtopic.php?t=136497
Steve E.
Site Admin
Post: # 23079Unread post Steve E.
Sun Feb 03, 2013 3:43 pm
Do you mean a soundscriber? I've never known what speed those recorded at. anyone know?
Angus McCarthy
Post: # 23081Unread post Angus McCarthy
Sun Feb 03, 2013 4:09 pm
timmy1 wrote:Thank you when I get the lathe I want to try recording on solo picnic plates with a fine needle and see how it will play on a 45 record player.
You actually don't want to use a sharp needle to emboss - you'l just end up scratching a gouge through the plastic. The idea is to press a groove into the surface. If you have any old, worn-down cutting styli you can sometimes get them to emboss by flipping them around backwards. Otherwise try sanding down the point on a gramophone needle to give a softer, more rounded tip.
timmy1
Post: # 23125Unread post timmy1
Mon Feb 04, 2013 7:46 pm
On a wilcox recordettte that has one speed can you put the 3 speed assembly mechanism from a newer recordette on to the 1 speed recordette thanks
Angus McCarthy
Post: # 23126Unread post Angus McCarthy
Mon Feb 04, 2013 7:53 pm
I'm not sure why you'd want to. If you have a 3-speed Recordette why not just restore that machine?
timmy1
Post: # 23130Unread post timmy1
Mon Feb 04, 2013 8:54 pm
I don't have a 3 speed one but if I can get parts from one I was refering to
Angus McCarthy
Post: # 23145Unread post Angus McCarthy
Tue Feb 05, 2013 8:18 am
It's very doubtful you'd be able to find just the transmission from a specific model like that - especially one that did not go through as many model years as the earlier single- and double-speed models. This equipment, though not impossible to find, is not as common as it once was.
timmy1
Post: # 23257Unread post timmy1
Mon Feb 11, 2013 6:18 am
On a crosley made in the 40's can they be modified to record at 45 speed?
timmy1
Post: # 23312Unread post timmy1
Tue Feb 12, 2013 11:29 pm
How much should I have to pay for a working wilcox gay recordette supposeding working
Angus McCarthy
Post: # 23331Unread post Angus McCarthy
Wed Feb 13, 2013 1:27 pm
If it's fully restored, I've seen a Wilcox-Gay go anywhere from $200-$400.
timmy1
Post: # 23337Unread post timmy1
Wed Feb 13, 2013 3:44 pm
A person has one he did not restore it but he says it works and he wants 350.00 for it. thanks
timmy1
Post: # 23444Unread post timmy1
Sun Feb 17, 2013 8:25 pm
I found a 3 speed wilcox record player and would the speed mechanism fit a recordette machine?
Angus McCarthy
Post: # 23454Unread post Angus McCarthy
Mon Feb 18, 2013 1:52 pm
Timmy, if you have found a 3-speed Recordio just restore that one. The Recordette was not the best machine even when they were new, honestly.
timmy1
Post: # 23467Unread post timmy1
Tue Feb 19, 2013 5:52 pm
Angus McCarthy wrote:Timmy, if you have found a 3-speed Recordio just restore that one. The Recordette was not the best machine even when they were new, honestly.
The trouble with finding another machine the other ones are very high in price.
timmy1
Post: # 23504Unread post timmy1
Thu Feb 21, 2013 7:31 pm
I bought a recordette and I found out the on off switch is stuck and won't turn. Would it be okay to take the knob off the shaft and spray a little pb blaster around the shaft and let it sit?
timmy1
Post: # 23711Unread post timmy1
Wed Feb 27, 2013 10:48 am
The on off knob is no good so I have to try to find another one to replace the switch.
timmy1
Post: # 23938Unread post timmy1
Fri Mar 08, 2013 6:39 pm
I had a friend come over he looked at the recordette. He said on 1 circuit he was tracing, calls for a 2 k resister and from what he saw there was a 10 k resistor
