It's an adapted Edison Ediphone dictaphone machine.
An advance ball system is used to ensure constant depth of cut. First time I believe that the ball system has been used for cutting round phonograph cylinders. It's adjustment is the round white circle top right .
The shiny cylinder grooves can just be seen.
The playback pick up ( a Shure cartridge) is at bottom left swung away from cylinder. This is mounted on a short tone arm fixed to a travelling carriage which tracks along the cylinder as it rotates.
The silver coloured home made cutter head is seen in the raised up position. (made from a 4 inch speaker with heavy damping to the stylus cutter mounted in a parallel motion mount).
There is also a microscope mounted at the rear....made from an old binocular plus eyeglass!
Although this machine records music it was designed to record Narrow band Television signals. I call it 'The Edikow machine' in memory of EDIson and Paul NipKOW who invented the rotating disc used for NBTV.
Albert.
