question on a manual about a odd wuton lathe recorder
record cutter 76
Post: # 27359Unread post record cutter 76
Sun Oct 06, 2013 5:58 am
helo is ther any people out ther how knows wer i can get a manual of this lathe cutter its a wuton 22 lathe record cutter /player
i love this forum !!! :D
record cutter 76
Re: question on a manual about a odd wuton lathe recorder
Post: # 27426Unread post record cutter 76
Fri Oct 11, 2013 3:05 pm
:mrgreen: i found out how this lhate works now and the engraver cutter /picup simes to work
the only thing to do Before i test cutting it is to put some oil in the mecanicks
and shift the main Cable to a new one it should be intresting to see this thing in action
record cutter 76
Post: # 27427Unread post record cutter 76
Fri Oct 11, 2013 3:08 pm
some Pictures
record cutter 76
Post: # 27428Unread post record cutter 76
Fri Oct 11, 2013 3:20 pm
her is a chematics over some of the functions
record cutter 76
Post: # 29079Unread post record cutter 76
Sat Feb 22, 2014 10:59 am
a info about the wuton recorder but my is a litle bitt older
funny anyway
Steve E.
Site Admin
Post: # 29092Unread post Steve E.
Sun Feb 23, 2014 11:27 am
Beautiful thing!!
record cutter 76
Post: # 29093Unread post record cutter 76
Sun Feb 23, 2014 1:38 pm
thanks this lahte maschine whas sold by a post delivery Company whithe name of clas olson the Company still exists to day .my maschine is what i self belive froam the year 1939 /40 some where in the anonsment the text told that this maschine is
good even for studio work whitche is litle fun to read and belive of course but it is a well build lahte that can i promise !!
agfamatic
Post: # 29130Unread post agfamatic
Thu Feb 27, 2014 12:03 pm
nice to see a swedish made machine here :D . seens to be a very nice machine to with magnetic cutterhead and 78 an 33rpm speeds
i will keep ny eyes open for one of those when i´m at yard sales/seconhand stores
record cutter 76
Post: # 29133Unread post record cutter 76
Thu Feb 27, 2014 2:01 pm
hej det är ett rent helvete å försöka hitta något graververk i sverige innan jag fann den här maskinen vilken tyvärr mig veterligen bara har 78 v som hastighet så letade jag i över femton år innan jag jag fick tag på den och jag fick köpa maskinen under förutsättning att jag inte sålde den till någon annan sen så fick jag dessutom betala en stor summa pengar till killen som ägde den
dom här grejerna är tyvärr riktigt dyra å skulle du springa på en på loppis så gratulerar jag dig till århundradets fynd jag tvivlar på att det nog finns någon stor chans till det .enklast är nog att betala en stor summa pengar för tex en rec o kut eller att som jag och så gjort bygga en själv vilket kan funka riktigt bra om man bara är teknisk och inte har tummen på fel platts
jag önskar dig lycka till med ditt sökande i alla fall och skulle du börja bygga själv (kostar inte mycket ) så kan du prata med mig om konstruktioner material mm
Med vänlig hälsning michael
record cutter 76
Post: # 30283Unread post record cutter 76
Sat May 31, 2014 5:08 am
its a german made lahte froam Bavaria if some one vounder ????
agfamatic
Post: # 30286Unread post agfamatic
Sat May 31, 2014 7:35 am
såg ditt svar först nu.
jag står faktiskt i begrepp att bygga ett graververk. jag har en gammal remdriven skivspelare från 50 talet jag planerar att montera en stor kraftig DC motor och bygga en styrkrets till.
själva matningsanordningen blir nog liknande den på amerikanska Prestomaskiner och jag har hittat en mängd fina mässingskugghjul av lämplig diameter från en trasig vevgrammofon samt kullager och några stycken gängstavar med M-gänga. dock det som saknas är aluminium skivor och stavar att bygga själva mekaniken av och för tillfället verkar jag inte kunna hitta det nånstans.
min konstruktionsidé är inspererad av denna artikel jag hittade på nätet http://alast.se/gram.html
jag har även varigt i kontakt med honom och har fått lite råd och tips
record cutter 76
Post: # 30310Unread post record cutter 76
Sun Jun 01, 2014 11:52 am
hej leta i gamla data skrivare så kan du få tag på glidstänger hoppas att du lyckas Med vänlig hälsning michael
record cutter 76
Post: # 30402Unread post record cutter 76
Thu Jun 12, 2014 7:36 am
skoj att flera personer är intreserade av 78 v gravering en sak jag glömde säga var att du kan köpa ett komplett slädsett med skruv från rollco sök på quadro table så får du se tyvärr är dom dyra ca 5000 kr tror jag
jag känner en som säljer sånna och lager mm om du behöver
mvh
