78rpm cuts w/ sped up source?
- leestavall
Does anyone know any reason I shouldn't cut at 78rpms, with a source that's been sped up, so that if played back at 45 or 33, it plays correctly? I've read the posts about people slowing their source down, cutting at 33 w/ the end result being a record that plays correctly at 45. Wondering if I can reverse that process..
Anyone?
Thanks in advance for your trollish knowledge!
Anyone?
Re: 78rpm cuts w/ sped up source?
You can do that, but it will kill the high frequency response. Consider the bandwidth of the head. Let's say 8 Khz, for the typical Recordio. That would reproduce at 4.6Khz at 45 RPM and 3.4 Khz at 33 RPM when slowed down. That's pretty poor performance.
- leestavall
Yup, tried it and thats exactly the experience I had. Thanks Mark!You can do that, but it will kill the high frequency response. Consider the bandwidth of the head. Let's say 8 Khz, for the typical Recordio. That would reproduce at 4.6Khz at 45 RPM and 3.4 Khz at 33 RPM when slowed down. That's pretty poor performance.
But if you are into lofi or doom metal and want to erase the high end.
Lo-fi or no-fi!
Lo-fi or no-fi!
