as many of you i bough at Souri last monday (not as many of you for the last monday part) the T560 with the full pack (only one meter still) and drive home happy with it.
As soon as i get home, i install everything but get a small problem : I can't listen from my CD player in my headphone (I do listen from the gramophone and I get signal from the CD player as i listen it on the cutter and i am able to cut it).
On Souri mix i just have to switch from Phone to line and that should work (and heklp me to optimise the sound) but it isn't ...
Souri answer me to check the manual (I double check my installation all day long) and as i believe i will not get much more answer from him i am writing here if somebody get the same problem and find the solution for it :d
T560 installation problem
