Neumann console upgrade and replacements
SopranoC
Post: # 47600Unread post SopranoC
Sat Aug 19, 2017 5:49 am
Hello, not found others posts about this topic on the forum.
I would like to replace the Neumann console for the cutting room, had a look on a fully digital console with Neve and Universal Audio plugins.
Have you hardware/software or solutions to recommend?
flozki
Re: Neumann console upgrade and replacements
Post: # 47602Unread post flozki
Sat Aug 19, 2017 7:02 am
if you can wait until beginning of the year. fully booked out until end of the year.
check:
http://www.flokason.ch/fs_flokason_gear.html
around 6k
or
http://www.vinylium.ch/platform/content/element/40/master-control-front_xl.jpg
around 18k
also 4 channel monitor controllers and everything you need to replace neumann stuff.
please direct email. no pm's i almost never check in here.
SopranoC
Post: # 47603Unread post SopranoC
Sat Aug 19, 2017 7:20 am
Good ones, but also looking for modern ones!
gold
Post: # 47711Unread post gold
Fri Sep 01, 2017 1:16 pm
If you want a four channel console your options are very limited. If you are willing to use a DDL then there are many more possibilities. Like a Maselec MTC-1X.
SopranoC
Post: # 47714Unread post SopranoC
Fri Sep 01, 2017 7:48 pm
gold wrote:If you want a four channel console your options are very limited. If you are willing to use a DDL then there are many more possibilities. Like a Maselec MTC-1X.
I have fully Maselec outboard EQ, Compressor, Limiter, Deesser and also MTC-1X.
I'm looking for the best solution to connect the new mastering console with the Neumann AM32 with VMS66 amp and SX68 cutterhead.
Any ideas?
Maybe Apogee?
gold
Post: # 47718Unread post gold
Sat Sep 02, 2017 6:51 pm
It sounds like you need a DDL. I don't know what is currently available. TC Electronics is a good place to check.
