I recently acquired a Vanrock and most everything about it seems self explanatory except the ENDING function. From what I can gather this will do a run out groove and then a locked groove to keep the stylus from skating across the center into the spindle. The lockout is in a fixed position but mine when it goes to the locked groove it doesn't manage to lock it.. it just keeps slowly incrementing the groove I guess until it crashes into the hold down weight.
Any suggestions on how to fix this?
Vanrock Recorder E-101
Re: Vanrock Recorder E-101
I'm considering unmounting the head from the Vanrock chassis adding longer wires and mounting it on a separate lead screw with a fullsize turntable to cut mono 12" records.
