Hanoi Amator Project (HAP)
This is my first post at Lathetrolls, after spending time Reading and learning, then try to do with what I already have, hope it works soon! Just show some pictures of my new project, just start! Pls give me comments and advices!
22050812_10210120658631313_1319018170_o by Nguyen Dang Thang, on Flickr
22016962_10210120653111175_1785126126_o by Nguyen Dang Thang, on Flickr
22016867_10210120653351181_650220873_o by Nguyen Dang Thang, on Flickr
22047432_10210120658071299_1077964221_o by Nguyen Dang Thang, on Flickr
22068663_10210120658151301_2050479104_o by Nguyen Dang Thang, on Flickr
22068957_10210120653711190_1346986374_o by Nguyen Dang Thang, on Flickr
22199120_10210146605239962_243377532_o by Nguyen Dang Thang, on Flickr
22171726_10210146605039957_1413310312_o by Nguyen Dang Thang, on Flickr
22171701_10210146605359965_2060958742_o by Nguyen Dang Thang, on Flickr
22140553_10210146604959955_670174540_o by Nguyen Dang Thang, on Flickr
22140346_10210146604599946_1951555650_o by Nguyen Dang Thang, on Flickr
22140415_10210146604479943_1242709201_o by Nguyen Dang Thang, on Flickr
Thank you!
Thank you!
- petermontg
Re: Hanoi Amator Project (HAP)
Looks like a fun project.
One thing, I wouldn't use wood to carry the over head. The mechanical movement could cause movement overtime in the support.
Peter
Peter
Peter Montgomery
+353(0)894926271
+353(0)894926271
What's the pitch of the leadscrew?/Where can i buy one?
Yes, I know its better if I use in metal, however it is more difficult to make now, I will rebuild in metal when I finish some other parts: head cut, speed control,..petermontg wrote:Looks like a fun project.
Peter
I'm wondering what should I choose the transducer: This one https://www.adafruit.com/product/1785 or https://www.adafruit.com/product/1784 or I DIY
pls give me advices, tk uuuuu!
Hi There,
Hope this helps
Regards
Soulbear
The Sparkfun/Adafruit type transducers are not your only options. Have a look here for instance :- https://www.parts-express.com/cat/exciters-tactile-transducers/18 I've made an as yet "Untested" Cutterhead, my Soul Sculptor Head :- https://www.lathetrolls.com/viewtopic.php?f=15&t=6556 using these transducers, however Fred used some transducers of a similar type with great results (https://www.parts-express.com/dayton-audio-daex30hesf-4-high-efficiency-steered-flux-exciter-with-shielding-30mm-40w-4-oh--295-240) check this out where Fred shows the making of his Cutterhead too :- https://www.lathetrolls.com/viewtopic.php?f=22&t=6866Hanoi wrote:I'm wondering what should I choose the transducer: This one https://www.adafruit.com/product/1785 or https://www.adafruit.com/product/1784 or I DIY
Hope this helps
Regards
Soulbear
Thank you Soulbear, this helps me alot! Actually Iam based in Vietnam, so have to try to find which one I can buy easily.Soulbear wrote:Hi There,The Sparkfun/Adafruit type transducers are not your only options. Have a look here for instance :- https://www.parts-express.com/cat/exciters-tactile-transducers/18 I've made an as yet "Untested" Cutterhead, my Soul Sculptor Head :- https://www.lathetrolls.com/viewtopic.php?f=15&t=6556 using these transducers, however Fred used some transducers of a similar type with great results (https://www.parts-express.com/dayton-audio-daex30hesf-4-high-efficiency-steered-flux-exciter-with-shielding-30mm-40w-4-oh--295-240) check this out where Fred shows the making of his Cutterhead too :- https://www.lathetrolls.com/viewtopic.php?f=22&t=6866Hanoi wrote:I'm wondering what should I choose the transducer: This one https://www.adafruit.com/product/1785 or https://www.adafruit.com/product/1784 or I DIY
Hope this helps
Regards
Soulbear
And how many Watts the transducer should be, Soul?
Soulbear! I've been waiting so long to hear your cutterhead!
I'm embossing with that parts express speaker, it does work fairly well, you can check out my thread here; https://www.lathetrolls.com/viewtopic.php?f=15&t=7323
I've got some of the small adafruit transducers on the way at the moment
Not sure if anyone else had the same issue (I'm a little rough..) but the coil did decouple from the cone on the parts express speaker, I managed to reattach it but had to forfeit the centering ring, so I get some wild resonant frequencies
What are the specs on the stepper motors? Better than nema17s?
Hi jjwharris,
How is your project going? This is the spec of my stepper motor (28BYJ-48 12Vol), it is small and rather quiet.
Diameter: 28mm
Voltage: 12V
Stepping angle: 5.625 x 1/64
Reduction ratio: 1/64
5-wire 4-phase can use ordinary uln2003 chip driver,
Can also be connected to a 2-phase use can make supporting the development board
Use, direct plug, easy to use stepper motor used in the development board
http://thegioiic.com/upload/large/3643.jpg
Diameter: 28mm
Voltage: 12V
I'm pretty happy with it, looking at improving the turntable and reducing stepper noise, that's why I'm interested in that stepper motor you're using, maybe I'll get one and give it a go.
Have you seen these stepper motor drivers?
https://www.youtube.com/watch?v=P3ebhi-vZRY
The silent step mode can lower torque, but, wow, that seems silent.
I think noisy or silent is not depends on driver, it depends on how many step to make around, microstep... So it is motor and the way to write code for Arduino.jjwharris wrote:Have you seen these stepper motor drivers?
https://www.trinamic.com/fileadmin/assets/Products/ICs_Documents/TMC2130_datasheet.pdf
Page 49 of that PDF explains the silentchop mode, from my understanding it provides more of a PWM control which results in a smoother motor motion, but also lower torque. I imagine the issue would be if it miss-steps, from not enough torque mucking up your LPI.
On my setup I still get slight stepper noise despite isolating the stepper motor with a rubber belt and butanol and foam between components.
I change the motor to 24v AC, 1RPM and plus some pulley, it is very smooth and silent. The speed now is 5mm/min (is the speed ok??)
I also change as clip
Cheers!
Cheers!
Looks great! What this thing that you touch with your finger at the end of the video is doing and how do you call it in english?
Thanks,
Bob
Thanks,
Bob
That is quiet!
There is a guide on Aardvark http://www.aardvarkmastering.com/riaa.htm
You need to be looking at lines per inch
- EpicenterBryan
You have a pretty course pitch lead screw there. The pulley ratio you have might be in the ball park for lead in / lead out - hard to tell from the video. If you swap the pulleys, it will get you closer to a reasonable rotation for normal grooves but still looks to fast for that lead screw to me. Can you tell us the pitch of that lead screw, and the RPM of the motor (or did I miss that)?
Haha, I dont know what to call it in English, I use that to carry the tonearm.boryo wrote:Looks great! What this thing that you touch with your finger at the end of the video is doing and how do you call it in english?
Thanks,
Bob
Thank you J, this help me much!jjwharris wrote:That is quiet!
My motor is a gear motor, if connect directly to pitch screw I can not turn pitch screw to move back when finish cutting or I have to wait same time if change motor direction. So I add one more pulley to cut off manually.EpicenterBryan wrote:You have a pretty course pitch lead screw there. The pulley ratio you have might be in the ball park for lead in / lead out - hard to tell from the video. If you swap the pulleys, it will get you closer to a reasonable rotation for normal grooves but still looks to fast for that lead screw to me. Can you tell us the pitch of that lead screw, and the RPM of the motor (or did I miss that)?
The pitch screw is 2mm/round, motor is 1 RPM so I add Pulley to increase pitch screw speed to 2.5 RPM.
