presto 6n ratchet assembly problem
- petermontg
ok, small but big problem.
my rachet assembly wont engage when my cutterhead carrige is engaged.
it works fine when the carriage is not engaged.
i have taken apart and re-greased.
i have a thinking that the little spring inside has seen better days.
any help/thoughts would be great.
regards
regards
Peter Montgomery
+353(0)894926271
+353(0)894926271
- petermontg
the rachet assembly is the worm gear part on the left hand side.
feedscrew stops rotating when weight of overhead is placed on the feedscrew.
the part is 6n-38 i think in a presto manual.
i have adjusted the overhead carriage to have as little weight sitting on the feedscrew maybe needs more adjustment
Peter Montgomery
+353(0)894926271
+353(0)894926271
- petermontg
- petermontg
- Fela Borbone
Re: presto 6n ratchet assembly problem
Hello Trolls,
I'm trying to repair the ratchet of a 6n. I unscrew rhe 3 screws that hold it toghether( are they?) But the thing dont seem to open...Can it be opened? Any ideas about how to do it are welcome...before I get mad with the torch and hammer!☺
Thanks for reading.
Thanks for reading.
- petermontg
Hi Fela,
It should come apart with a bit of effort.
A good cleaning and re-grease of the ratchet solved the issue for me.
Peter
Peter
Peter Montgomery
+353(0)894926271
+353(0)894926271
- Fela Borbone
Thanks for your answer,Peter,
The ratchet was filed with epoxi! But managed to open it with no damage to other parts.
Here's a pic if somebody wonders how it looks like:
The 8dg has a similar setup in the overhead.
Mine was in a similar condition, after years of sitting the grease solidified and had to be carefully scraped out with some "welding picks" i had. (Just a really cool pick set for some reason associated with welding at the local hardware store.)
What's odd is, i have never seen a new formula of grease do that. I wonder if it's like old formula rubber, where they perfected it as time went on. (Older rubber over time turns rock solid and crumbles away.)
Just a hunch. Nothing solid to back it up.
