Hi JHL,JHL wrote:Thanks so much for davor!he help me a lot and we finally found the noise reason is may cause by the broken stylus
it's not surprising your stylus is damaged with the wrong set up of the VR.
I suggest, first make sure all the settings of the VR are set within certain safe parameters. And only thén change the old damaged stylus for a new / re-sharpened stylus.
Otherwise your stylus will be damaged again. Damaging the stylus can happen rather easily!
