I try the plastic pieces for my coils. I made cone shape, as mark suggests me. I just glue them with super glue in the center of the coil former.
It was difficult to attach them without any distortion but I made it.
The problem now, is to attach the brass rods to the torque tube. A sine wave is good enough only from then transducer, but when I attach them to the torque tube I can listen distortion. I don't know if this happening because of the bad connention to the tube or not the accuracy of 45 degrees of my design. Maybe both.
Could you suggest a more precise method of the connection on the torque tube???
Anyway, I try the cutterhead to see what happens.
This is the result: This is a cut with sapphire stylus, no heat and no suction.
The signal chain is wav file - 2 FAB fitler in series (trying to make flat the response of my head) - Izotope Imager (to make mono bass under 150Hz) and a high frequency limiter after 10kHz.
You can listen now that finally that I have high frequency response till 14k approximately.
This is makes me happy for now,
BUT, there is a lot of harmonic distortion in the "tones" part of the audio. I believe this is because of my bad connection to the torque tube.
Also, as you can listen there is a lot of wobble in this cut, because maybe of not enough torque of the Technics Sl100 mk2. I don't know if the 1,5Kg/cm is good enough for this application. I try to keep the downforce weight as low as I can, but this causes a lot of skips, because the grooves are too shallow.
Do you believe that I can achieve better results with technics turntable? Or should I try a turntable with more torque? Numark TTX for example?
Is the downforce weight of cutterhead matters to avoid this terrible wobbles?
Another query: Is the swarf affects the distortion of the signal?
Also, I must say that I have no dBmeter to measure the level of this cut. The only thing I do, is to use my multimeter in the output of my amp.
The amp was set to full. (150W at 4Ohm).
In the white noise part there 13,5Volts approximately. In 1kHz it is 1Volt. If I go louder to the 1kHz, the harmonic distortion is bigger. Is this 13,5 volts are too big signal?
I was thinking to try the small adafruit transducers (3W @ 4Ohm), as Ciuens try them in the past. As I learn from here, less mass means less power.
Anyway, next step is to built a more rigid lathe, to continue my tests. And of course, I will try another cutterhead with more precise design (especially in the connection of the brass rods to the tube). Also I have to start thinking about the suction part of my project.
Thanks for reading this,
Any comments or suggestions are welcome,
Happy Easter,
Sifis
