i need help to build a good lathe recorder
- record cutter 76
helo i need help to construct a nice lathe i have some problems white motor vibrations
- record cutter 76
Re: i need help to build a good lathe recorder
i need a good mono cutter head if some one have one for sale
- dubcutter89
why not use your Lyrec?
Lukas
Lukas
- soeffingodly
I suggest hitting up piaptk (Mike) and seeing if he has any heads sitting in the lathe cave. He usually does but it depends on what work they may need to get them rocking again.
Mike - Still interested in one of those 5C's when you get around to it. =)
- record cutter 76
my lyrec need som tlc the motor dosent seem to work it jump when you start and then no moren and the rest is up for a big resturation i whant some thing that are more reliable i have it more lika a museum pice than a record lathe right know so its better to try to build the ultimate thing than use to old stuff i think !dubcutter89 wrote:why not use your Lyrec?
Lukas
- record cutter 76
[quote="soeffingodly"]I suggest hitting up piaptk (Mike) and seeing if he has any heads sitting in the lathe cave. He usually does but it depends on what work they may need to get them rocking again.
Mike - Still interested in one of those 5C's when you get around to it. =)[/quo
okej thank you for the tip . what 5C´s ??
- dubcutter89
Have you tried to spin it by Hand and then switch on the Motor? (really spin fast - at least 78rpm...)my lyrec need som tlc the motor dosent seem to work it jump when you start and then no moren
I imagine the lyrec uses a synchronous Motor that does not start on ist own, you have to do by Hand!
Same as with old neumann and telefunken portable lathes...
Check if it is 110V or 220V !
Give it a try!
And if not I'm more than happy to give it a nice place in my lathe museum
Lukas
Check out the KNOP lathe project.
- record cutter 76
i while do that thank you for the tippXertz wrote:Check out the KNOP lathe project.
- record cutter 76
her is a plan on my diy new record cutter i while use a 16 inch platter and a front weel car berings from a golf mk 3 and a roof fan white direkt drive
