Inkjet printing on record blanks?
professorb
Post: # 53816Unread post professorb
Fri Aug 02, 2019 7:29 pm
I have access to a flatbed inkjet at my day job and am thinking about trying to print on uncut side of a one-sided 12" record. Anyone have any experience with this? Tips or advice?
piaptk
Re: Inkjet printing on record blanks?
Post: # 53820Unread post piaptk
Sat Aug 03, 2019 2:01 am
I silkscreen b-sides, but have never used a printer on them. Its especially cool when you print the image inverted on clear polycabronate so the image shows up correctly on the cut side.
professorb
Post: # 53822Unread post professorb
Sat Aug 03, 2019 11:41 am
I’ll have to give that a try!
okpanda
Post: # 53861Unread post okpanda
Wed Aug 07, 2019 12:23 pm
before or after cutting? if it is before cutting, i would think that it would interfere with a clean cut - after cutting and i would be concerned about ink filling in grooves. are you planning on the printed side being playable?
professorb
Post: # 53863Unread post professorb
Wed Aug 07, 2019 1:40 pm
I was thinking one-sided records and printing on the opposite side.
Tim w
Post: # 53865Unread post Tim w
Wed Aug 07, 2019 1:54 pm
Do you have a printer that will advance the record under the printhead ? I would also be concerned about any kind of moisture washing away the image.
professorb
Post: # 53869Unread post professorb
Wed Aug 07, 2019 3:51 pm
It's a 5ft x 10ft vanguard flat bed. The material is placed on the bed and held in place with a vacuum while the print head travels back and forth above the material. I could probably print 32 at a time if I lined them up right.
piaptk
Post: # 53870Unread post piaptk
Thu Aug 08, 2019 12:06 am
Ive embossed on poly over Stazon stamp ink or sharpie with no discernable difference.
In theory, i would think that if a diamond is tough enough to cut through plastic, it should be able cut through a very thin layer of ink. The audio would be held below the surface layer anyway.
symatic
Post: # 53897Unread post symatic
Mon Aug 12, 2019 9:53 am
i'm tihnking the same - if it can cut through plastic, can't it cut through ink/different textures?
okpanda
Post: # 53902Unread post okpanda
Tue Aug 13, 2019 12:26 pm
i wouldn't be concerned about cutting through it, just gunking up the stylus in the process.
okpanda
Post: # 53903Unread post okpanda
Tue Aug 13, 2019 12:30 pm
oh in terms of printing on the blank side though - i vaguely recall hearing about some kind of clear coating you can spray onto a surface to make it printable with regular ink. let me see if i can find out what it was.
also, do you know the maximum media thickness that can be fed through your printer? a 2mm blank might be too much, ie paper is not usually that thick.
okpanda
Post: # 53908Unread post okpanda
Wed Aug 14, 2019 1:09 pm
this is what i was thinking of but it appears to have been discontinued:
https://www.goldenpaints.com/technicalinfo/technicalinfo_digigrnd
there might be similar products though.
