What Anti static spray
nikc
Post: # 59622Unread post nikc
Fri Oct 15, 2021 5:02 am
Hello there trolls.
I have been cutting for 4 years with an MSS mono lathe, with myshank diamonds and blanks.
I have used various anti static sprays, mainly Staticide and my favorite Turtle wax: Wax and dry.
But you can only get Turtle wax: Wax and dry in the USA, so getting it is tricky. ( I am in the UK.)
So I emailed turtle wax company and they said the equivalent in UK is called Turtle wax: Wax it Wet.
But it's just not as good and very greasy.
What spray does anyone else use?
Best Wishes
Nik
Pearl Home Records
Nik Clifford
Pearl Home Records
David34
Re: What Anti static spray
Post: # 59641Unread post David34
Tue Oct 19, 2021 5:19 am
Someone needs to work out what is in Souri's as it works well.. .
handcut
Post: # 59643Unread post handcut
Tue Oct 19, 2021 10:15 am
The tears of people he's ghosted
Post: # 59661Unread post tragwag
Fri Oct 22, 2021 11:10 am
did you have any luck with the Myshank anti-static?
I used that and it worked fine.
I started making my own out of water and a few drops of dish soap, also good.
these days I use water + 10 sprays of this:
https://www.grove.co/catalog/product/wrinkle-release-spray/?v=3831
might be worth trying any readily available laundry anti-wrinkle spray without scent
nikc
Post: # 59681Unread post nikc
Fri Oct 29, 2021 12:04 pm
Hello
Thanks for the response. I have been trying water and dish soap and it's been working fine so far. So will stick to that for now and forget the car wax etc.
Yes I wonder how you'd analyse what's in bought anti static spray. My dad would be able to help if he was alive!
Nik Clifford
Pearl Home Records
Post: # 59698Unread post tragwag
Fri Nov 05, 2021 10:17 am
great! glad it helped, if you find something else that works or even works better, post it here!
