Picture disc
msartori
Picture disc
Post: # 67382Unread post msartori
Wed May 07, 2025 6:42 am
To glue the two 1-millimeter transparent discs for the picture discs, do you use spray glue or double-sided tape?
Because spray glue makes a mess...
Thanks for help :D
spinnertownblanks
Re: Picture disc
Post: # 67385Unread post spinnertownblanks
Wed May 07, 2025 9:26 am
We used to use 3M or Cleopatre spray glue when making ours, we found some sprays better than others for sure. Here are some examples of ones we made www.instagram.com/p/Cs3gAJFsYPm/?img_index=1
www.spinnertownblanks.com
zukote1991
Re: Picture disc
Post: # 67396Unread post zukote1991
Sat May 10, 2025 12:20 pm
Hi! For picture discs, most people recommend using a thin layer of clear double-sided adhesive film instead of spray glue — it gives a cleaner, more even bond without the mess or warping. Some also use pressure-sensitive adhesive sheets that are specifically made for laminating. Just make sure to press everything evenly to avoid bubbles. Hope this helps!
Hello
spinnertownblanks
Re: Picture disc
Post: # 67398Unread post spinnertownblanks
Sun May 11, 2025 6:27 am
Good to know! Picture discs certainly aren't our speciality :) Do you have links to one's you recommend?
Jccc
Re: Picture disc
Post: # 67399Unread post Jccc
Sun May 11, 2025 12:18 pm
i have also used 3M spray glue and never had any issues with bubbles or warps.
but i usually just made 1 sided post card picture disc
what i usually do is cut the or emboss the music on the clear plastic im using and then print the image out on card stock paper.
I then spray the paper with the image with the 3M spray glue and place the record that has the music onto the paper with the glue.
