Professional vinyl record lathe step by step
zdenek
Re: Professional vinyl record lathe step by step
Post: # 67195Unread post zdenek
Thu Apr 03, 2025 2:09 pm
the recording sounds like it's from another world or not of this earth or it's as old as the Holy Bible, TURN YOUR HEADPHONES DOWN A BIT because there's some crackling, nothing funny, I don't know what caused it, the head works fine, I burned a few, maybe 15 fuses, the transducers didn't burn out [fortunately for me...]
Constructive comments are very welcome, [the dollar is falling, that worries me a bit...]
https://www.youtube.com/watch?v=q1ANU-cUu34
Estrada
Post: # 67197Unread post Estrada
Thu Apr 03, 2025 9:01 pm
Definitely some surface noise. What was the separation like? I don't know much about how DMM heads work so not sure I could offer any advice. I recall reading a theory that they utilised a 60khz carrier frequency to assist with cutting, though I think this was not the case but rather the head assembly was designed in such a way that the stylus had a natural vibration at 60khz when cutting, which in turn helped with cutting nice silent grooves. A bit beyond my knowledge though.
zdenek
Post: # 67209Unread post zdenek
Sat Apr 05, 2025 7:24 am
I made this recording to check the possibility of recording a 3-inch copper record in antiphase on the axis at 19 rpm and whether the voice would be understandable. As you can hear, the groove tracking is very good [30 microns], vertical modulation is stereo [no difference heard at all]. It is possible, so the experiment was a success.https://www.youtube.com/watch?v=McsOVNdNI5w
zdenek
Post: # 67226Unread post zdenek
Mon Apr 07, 2025 3:52 pm
Conclusion.
In the brass head we used the design solution of the cutting head
Danish DSS and JVC clone included in the patent, it is wrong by design and it is not worth bothering with it. Heads constructed in this way do not work properly. We copied this Danish solution and we believe that it is bad from the ground up and we believe that they are not worth a pound of hair.
The correct design solution is the WESTREX USA head and its later German clones sx...etc.
Even a very simple design solution using small tweeters based on the principle of operation of WESTREX USA heads are at least ten orders of magnitude better than the bad ones I mentioned above.
zdenek
Post: # 67227Unread post zdenek
Mon Apr 07, 2025 4:08 pm
https://www.youtube.com/watch?v=-9vGIbm9SlQ
Here is an example of a recording with a head made of computer speakers, it is difficult to determine the power of the speakers 1 to 2 Watts 8 Ohms, recording by pressing a groove with a stylus in the CD on a very primitive and light amateur device ... You can compare, not everything that looks like a pig and squeals like a pig is a real pig .... :wink: :)
zdenek
Post: # 67233Unread post zdenek
Tue Apr 08, 2025 4:29 pm
SAL74B [SALOMON] input amplifier for a German system with low output level feedback heads. Personally, I think that the FB [red hrame ]amplifier developed by the Swiss company FS has better parameters than the original SAL 74B. We copied both and the Swiss FB amplifier made on the AMERICAN SMM2019BNZ symmetrical voltage amplifier has better dynamics, better symmetrical balance, lower noise, lower distortion. So the Swiss one is really worth recommending and is really good. Someone posted a diagram of this Swiss one. There is an error in the diagram. If anyone wants, I will indicate what needs to be added to make it work properly. [I answer emails directly here.swisse https://www.lathetrolls.com/download/file.php?id=13317&mode=view
zdenek
Post: # 67247Unread post zdenek
Thu Apr 10, 2025 2:40 pm
I didn't know where all this noise in my recordings came from, this signal comes from the power amplifier that I feed into the cutting heads, now I've connected the speakers. A lot of noise is introduced by the camera and microphones.https://www.youtube.com/watch?v=puSiewB1UIU
zdenek
Post: # 67259Unread post zdenek
Sat Apr 12, 2025 6:41 am
My PC monitor broke so I took out the plastic frame and cut it to a round size [quickly] it's smooth on one side, I don't know what material it is, plastic etc..., the blade cuts nicely. I recorded it with sapphire... something like thathttps://www.youtube.com/watch?v=97Wv8hYyDxg :)
zdenek
Post: # 67264Unread post zdenek
Sat Apr 12, 2025 2:51 pm
Such a small sapphire embossing on a CDr [quite well and the voice is well understandable]/
Low recording level around -20dB, you can hear noise and the vacuum pump. I only turn off the vacuum pump from the 9th minute, you can't hear the air flowing in the recording. All in all, for amateur recordings, recordings on CDR are quite good.
But soon there will be a 14 [12] inch copper plate, electroplated, we'll see how it turns out. The plans include variable pitch and depth, maybe in 2-3 months the machine will be fully functional. I think it was worth doing, even for fun, but it's worth it, I suspect that King Edison would be very jealous of such sound quality... [even this analog recording on CDR]. :) https://www.youtube.com/watch?v=3Gmb0ffPk9o
zdenek
Post: # 67342Unread post zdenek
Fri May 02, 2025 7:28 am
Cool story.
I promised a friend a long time ago [a very pretty girl] and she sings very nicely https://www.youtube.com/watch?v=rCQ3iJLuw8M. So I suggested to her that I make a machine for recording vinyl records. I met her recently and I told her that my machine is ready and would she give me her voice for the recording. The girl replied: of course! With pleasure! I want you to record me on a vinyl record! Ok I said. She came, I did the mastering on a PC, I recorded the girl on a pseudo vinyl and I said to her listen; ...., the girl listened to the recording with her voice and said to me: I thought you would like something more than my voice that's why I gave it to you, now that I listened to this recording according to your equipment you must have been joking with me! This is rubbish! No one will buy such a recording! So you have to improve the quality of the recording a lot to get my voice again because otherwise I won't give you more! Do you understand?! That's what this beautiful lady told me...Ole! :oops: :D https://www.youtube.com/watch?v=AH6vEflQz1M&t=23s
zdenek
Post: # 67351Unread post zdenek
Sun May 04, 2025 7:52 am
If you don't want to be cheated, ask the seller to make a movie for you with the head you want to buy from him with the signal entered into the line input of the computer or camera. If the seller insists that he can't record such a movie for you for various reasons, it means that you will receive a head that records as badly and with a narrow band [no bass and treble] as in this movie and don't expect it to be better. Sellers of supposedly professional heads made in a garage do not accept returns because they claim that the heads are jewelry. Listen to the shoddy recording :!: :!: :!: .https://www.youtube.com/watch?v=IAVBZ40mcI0
zdenek
Post: # 67463Unread post zdenek
Mon May 19, 2025 8:43 am
here is my latest solo recording on cdr with very high dynamics https://www.youtube.com/watch?v=VWKz2apaY30 :D :D :D
a fly doesn't land... there is no improvisation here, as the Swiss recording says: if you don't like how I did it, do it better, I'd be happy to compare.... :D :D :D
