using 5 year old transco lacquers
- dietrich10
anyone have experience using 5 yr old or so transco/apollo lacquers?
I have a box here that I hope not to waste. not much luck getting chip pickup right so far on a few attempts.
D
D
cutting lacquers-vms70 system
Send them to me and I will use them m8
It is all about applying heat with lamps.
2 x 30w spots
Lazar temp gun
Run on the table for about 4 mins until it gets to about 26 to 30 degrees.
Pull one lamp away if it is getting to hot.
Watch the chip - if it balls up around the stylus it may be not enough heat or to much.
You will have to play.
Oh yes I use 50 year old ones and all is fine.
Have Fun....
2 x 30w spots
Lazar temp gun
Have Fun....
Happy to learn something new.
- dietrich10
- subkontrabob
Today I've used 54 year old Master Sound System lacquers (12 inch) and Pyral masters (14inch, don't know the age).Simon wrote: Oh yes I use 50 year old ones and all is fine.
Just a random lamp for heating, no lazer temp gun, no bells and whistles, works like a charm
chip gets sucked up perfectly, although it's a standard groove vintage head without stylus heating!
I'm a lucky man
Any age should be OK and heating probably improves performance, as long as they're not leaching palmitic. If so, they may be too dry to cut. Over the weekend I pulled out an old box of Allied's I had from the late 70's, all of which had palmitic on their surfaces - cleaned them a bit, then did some test cuts on an old Federal Radio Recorder I'd just finished working on and the thread was very dry - like unconditioned hair. Probably pretty flammable as well.
- powerstrip
Couple things to.say here
I had.a box of 16 inch audiodisc.shippid with my cutter and they all had a 'curdled' look about them. Stuck together, I pulled them.apart delicately. Some of the lacquer which was stuck together looks ' cuttable'
The other box of 25-1 red label audiodisc was included; they were more.well kept than the 16s. I pulled them apart so carefully, kept each one in its own plastic sleeve. After that, I cut on them well using the methods described above. But on a couple of the red labels, if you hold it to.the right angle, you see slight curdling.
Point is, if they are sealed nicely, they almost always come out clean as a whistle. Just look for that lacquer smell. If its dried up there will be no vintage smell
