Handcrank cutters? Do they exist?
I've been reading about edison players a little bit, and it seems like the record function was a removable piece...
I don't have any to look at in person so any help would be great.
This looks like the cutter
Yes, that looks like the top of a recorder housing; underneath it should look like this:
Sorry I have an older digi cam which won't macro very well. If there is a stylus and it looks damaged, just heat up the holder and rotate with a pair of tweezers to a good spot. An Edison cutter is not much more than a sapphire rod with a small 'dent' ground in the end to make it sort of cup shaped.
The holder is easy to make out of a soda can if there isn't one, but if you don't have a stylus I'm not aware of anyone making reproductions. Complete units do come up on ebay very often though. Hope this helps.
wow those pictures help a lot!
thanks.
the whole home recording thing for cylinders is really intriguing
thanks.
