AD1202 for sale
montalbano
AD1202 for sale
Post: # 63596Unread post montalbano
Mon Oct 30, 2023 3:37 am
Hi all
We are selling:
1x AD1202 record press, s/n 314, w/ extruder and safety barriers
Double pressure system, hydraulic block with new Hawe valves
1x hydraulic unit, Bersanetti, with accumulator
1x set of original Alpha moulds, dated 1985 approx., never reprofiled - hence hardened and finished like they were sold back then
1x set of rings (original 45° Alpha or new, heavy 45° rings by Wilh. Schaefer)
1x controller with 3x Telefrang I/O 24 cards, 1x CPU card w/ programmed Eprom, 1x C27 card
Along with the ordinary maintenance, this press has recently got a new seal in the bottom of the ram (replaced 6 months ago) and a new seal in the extruder's gearbox.
Machine can be seen in operation and records can be checked under the microscope (we have our Neumann VMS here, just in case).
Selling price € 55.000 ex works - not negotiable. No pictures - you have to come over here and make it run. PM if interested.
For the bravest of you, we are also selling another AD1202 complete record press which needs to be partially reassembled. Job can be done by us (it won't be an overnight thing, though) or by the buyer, if he is able to, so I am not putting any price here - just PM if interested, and we can work it out. Also, in this case, all parts are available: press, extruder, hydraulics, moulds, rings.
http://www.phonopress.it
