several Machines for Pressing Plant up on sale
andybee
Post: # 69416Unread post andybee
Sat Apr 11, 2026 10:44 am
here we go:
-Alpha Toolex 702,7" Auto Press, fully overhauled & tested (work in progress)
-Newbilt 12" Automatic Record press, press new, extruder overhauled (work in progress)
-Alpha Toolex 12" automatic sleever (needs work) as project or overhauled & tested
-7inch preformer (cuts & forms in one step) with built in hydraulic pump, overhauled.
-TTT 1" centerhole punch with microscope arm
-Mother polishing machine, manual
-Label punch hydraulic, with built in hydraulic pump.
-two Europa Plating galvanic baths, only frames and some parts, as project or overhauled
with new electronics & DC sources, depending on needs (preplating or main plating)
-10" galvanic cell with 400A DC source, left/right moving/rocking, 4x 10" position including rings
sulfamate inside, but not sure if it is still o.k., was standing arround some time...
-silvering bin including walter SIL silvering gun, fully working.
-rockin table with 3x cells for preperation for silvering, working.
have photos & more infos, please contact me via email: cut@abmastering.de
thanks for watching ;)
