Wanted 45 RPM idle wheel presto 6n
dhturbo1
Post: # 11349Unread post dhturbo1
Fri Nov 12, 2010 9:03 am
Hi,Im Looking for a 45 RPM idle wheel for presto 6n lathe.Thanks
dhturbo1
cymbalism
Post: # 11352Unread post cymbalism
Fri Nov 12, 2010 10:30 am
Do you mean the adapter for the motor shaft? I'm not sure they made a drive wheel for 45 on a 6N
all the best!
- tommie 'plan 9' emmi
dhturbo1
Post: # 11355Unread post dhturbo1
Fri Nov 12, 2010 12:29 pm
Hi,sorry no i mean the idle wheel,the rubber wheel that replaces the 78rpm one to make the presto 45rpm.Thanks
dhturbo1
petermontg
Post: # 11356Unread post petermontg
Fri Nov 12, 2010 1:15 pm
second on that, looking for one also, maybe two
if mike is out there. any ideas where to get one?
Peter Montgomery
+353(0)894926271
Post: # 11358Unread post markrob
Fri Nov 12, 2010 2:56 pm
The idler diameter has no effect on the platter speed. You need the adaptor to fit over the motor shaft. I made my own and can give you the dimensions if you are interested.
SueDenim
Post: # 11359Unread post SueDenim
Fri Nov 12, 2010 3:24 pm
I'd be very interested to have those adaptor details Mark.
Please feel free to PM them to me! ;)
Sue D.
x
dhturbo1
Post: # 11360Unread post dhturbo1
Fri Nov 12, 2010 3:31 pm
Hi,ok i seem to be getting it wrong,my presto already has the adaptor on the motor shaft & is set to run at 33/45rpm so i guess its the 78 Rpm wheel is what im after the double wheel to the right of the machine.Thanks
dhturbo1
Post: # 11361Unread post piaptk
Fri Nov 12, 2010 5:51 pm
You probably need to have an adapter. You might be able to cut down the lowerwheel of a 78 idler, if you do the math and have Terry rerubber it to a certain diameter. But you also might have problems getting the whole mechanism over that far. It's the motor capstan that determines the speed... 33rpm for the smaller top part and 78 for the thicker bottom part. Never tried it, but thoguth about it and someone who knows about this stuff told me it probably wouldn't work, so I jsut bought a couple of adapters on ebay. But, i've been told plenty of things by people who acted like they knew that turned out to not be the case... so...
petermontg
Post: # 11362Unread post petermontg
Fri Nov 12, 2010 5:52 pm
hi mark
any chance of passing along those details, Pm them or just post them here
would be greatly appreciated
peter
Peter Montgomery
+353(0)894926271
Techie
6N 45 RPM
Post: # 11364Unread post Techie
Fri Nov 12, 2010 7:10 pm
Hi. I'm new to the group - Glad you're all here.
I had some experience with the 6N. There is definitely an adapter for the motor shaft. If I'm not mistaken both of the idler wheels were the same diameter, but were positioned at different levels to engage the top or bottom of the motor shaft. If you have the 45 adapter but you're missing a rubber wheel, try changing the location of the one you have and see if that works.
Hope I helped rather than confuse.
Post: # 11367Unread post markrob
Fri Nov 12, 2010 8:45 pm
I posted about this some time ago. Here is a link to that thread:
https://lathetrolls.com/viewtopic.php?t=1661&highlight=&mforum=lathetrolls
I think this is enough info to fabricate an adaptor.
Here is a link to a photo of a commercial adaptor that I found for sale on Ebay:
http://home.comcast.net/~markrob1066/pwpimages/Presto%2045%20Adaptor.jpg
This is a nicer approach than mine as I did have to modify my lathe a bit (tapping for a 10-32 screw). This one just slips over the motor shaft and is held in place by a setscrew.
dhturbo1
Post: # 11368Unread post dhturbo1
Fri Nov 12, 2010 9:38 pm
Hi everyone,thanks for all your replys but i think were missing the point here, i already have the 45rpm adaptor what i dont have is the 78rpm dual idler wheel which is what im after in order to get the 45rpm speed,the number in the presto manual is 6n-2 hope this helps.Thanks
dhturbo1
SueDenim
Post: # 11370Unread post SueDenim
Sat Nov 13, 2010 5:19 am
@dhturbo - apologies for semi-hijacking your thread mate!
Hope you find some help with your idler wheel ;)
Sue D.
x
petermontg
Post: # 11371Unread post petermontg
Sat Nov 13, 2010 7:42 am
west-tech.com
gib might be able to help you or point you in the right direction
Peter Montgomery
+353(0)894926271
dhturbo1
Post: # 11372Unread post dhturbo1
Sat Nov 13, 2010 10:33 am
SueDenim wrote:@dhturbo - apologies for semi-hijacking your thread mate!
Sue D.
x
No Problem at all.Thanks
dhturbo1
