WTB: Presto 6N or equiv
Wink Junior
Post: # 1130Unread post Wink Junior
Mon Mar 26, 2007 1:02 am
I was bidding on an auction for a Presto 6N and it fell through. I'm looking for a lathe to cut demo 12" discs for local DJ's and doing special one-off projects, etc.
So I'm not wanting to drop $20K on a full system, but would like something that's better than the Vestax VRX-2000 - although perhaps that one doesn't suck as much as ppl have said it does? I'm not looking to do audiophile recordings, rather fill a niche market for ppl who want demos, dub plates, and as said, special projects.
If anyone has one for sale, or can suggest other alternatives to it in the same price range/quality, and/or has opinions about the VRX-2000 - I'm talking to someone about one of those for US $6K w/extras but think that's a bit much considering I've heard the results are shite and the cutting needles are good for about 50 discs max.
Anyway, opinions, offers, anything most welcome! Cheers, Wink
Cutterwoller
Post: # 1260Unread post Cutterwoller
Wed May 09, 2007 2:07 pm
Yes, the vestax is crap. Do not buy it.
I would recommend that you get a presto lathe. They come up on ebay all the time. They were very very popular in the day and there are loads around.
With this, you can get the presto head with it which will give you good results. But a grampian head will be better and louder. You should be able to get all this for under $3000 max. If you had this setup of a presto lathe and a grampian system, you will be cutting commercial quility records. However, you need alot of practise which can be expensive (matierials). Best to get someone to show you.
Lewis
JayDC
Post: # 1266Unread post JayDC
Sat May 12, 2007 5:11 am
I cut "commercial quility records" with my Presto 1-C head. I dunno why everyone is so GRAMPAIN. Seems like just more money to spend..
If I ever upgrade it will be straight to the vinylium sc-99...
Cutterwoller
Post: # 1269Unread post Cutterwoller
Sat May 12, 2007 7:29 am
Fair enough if the Presto gives you good results. A few records at columbia were mastered with those I think. But, the reason I say grampian is better is because, it can cut louder and a better frequency response. In my opinion is just sounds better, alot more open sounding.
If I were going stereo, as I see you want to, I would get the Westrex system. Sounds amazing. You'll need the right amplifiers tho. Most people let thier systems down by having crappy transistor amplifiers, the amps are half the sound. Nice valve ones will do the job!
JayDC
Post: # 1273Unread post JayDC
Sat May 12, 2007 1:59 pm
Will the westrex fit the presto 6n?.. I was looking at pics of one, and can't imagine how I would fit it..
Cutterwoller
Post: # 1278Unread post Cutterwoller
Sun May 13, 2007 7:28 am
Hmmm. not sure, im sure you could make somthing so it will screw on. I think you have to make some special box to fit the sc-99 onto the presto?
motorino
Post: # 1282Unread post motorino
Sun May 13, 2007 11:04 am
i believe you dont need very special parts :wink:
http://www.floka.com/lofi/portable_lathe.html
Marcos
Cutterwoller
Post: # 1283Unread post Cutterwoller
Sun May 13, 2007 11:21 am
Yeah, maybe the westrex would be hard to fit on, but then again those lathes as great as they are (I used one for ages) were designed for portable use and so we not really designed for top notch cutting heads to fit on.
And wow, that vinylium amplifier looks mega cheapo! Looks like a toy! The Grampian amp comes in two pieces, the power supply and the amp. The power supply itself is a two man job to lift, and its mono! If somthing is big and heavy (and big knobs!), its bound to be good quility.
But yeah, Iv heard a few cuts of those vinylium systems and I wasnt very impressed, sounded tinny and weak even if cut loud, there was distortion also when cut to peak about +2db.
flozki
Post: # 1285Unread post flozki
Mon May 14, 2007 9:36 am
jayDC:
westrex no chance on a presto. or at least it doesnt make sense. weight, and also size you wont be able to cut the whole recording area....
also the stylus will be far before the center line...so then you have to change the whole overhead.
lewis D wrote:
"But yeah, Iv heard a few cuts of those vinylium systems and I wasnt very impressed, sounded tinny and weak....."
oh boy, what kind of cuts did you heard???
i bet i rock every system against the wall with a sc99 system, even i have no problem to compare to full neumann system in a one to one comparison.... there is a difference. but i would say if it comes to loud cuts or bass. i can stand behind...work with the shit and then judge.
lucky i have westrex,neumann AND sc99. so i can compare. even with BIG BIG BIG westrex and even BIGGER neumann tube amps. but all the big stuff gives you around 60-80 watts. and the "cheapo toy..hehehehe" (hand built, swiss made) vinylium amp gives you even more.. and i can carry around the world, even if i think its fucking heavy...
i worked a lot with grampian as well. just another class.sorry. definitely not comparable. a piece of moving iron developed around 1930. vibrates, adds resonances like hell. all this can make sound really fat. can be the right cutter for some kind of music, can be the nightmare for others...
there are also freaks swear by mechanical recording. they say everything after introducing the electrical cutter head sounds like crap. and i can understand what they mean. they had BIG, BIG horns to capture the sound. must be good.
but i know the feeling:
to drive a 49er buick makes more impression than driving a small volkswagen.
i love to cut with a scully, westrex system.... on a nice, sunny day. no hustle. no long cuts....just to enjoy cutting a nice record.
cheers.
f.
equipment is not all. lee perry had only 4-channels. the rest was magic...
ps: if you are interested to know how it sounds. you can order a plate at vinylium. one side with the kingston, the other side with the neumann system. these guys dont have to hide something. ...whenever you are seriously thinking about a nice cutting system do this test.and do it with others (when you can do this), check the sound ,maybe the price tag and and decide.
JayDC
Post: # 1286Unread post JayDC
Mon May 14, 2007 1:50 pm
I definately want an sc-99, just wish they had a "jayDC" special.
