Boiler 200 psi 35hp Parker
VFAU
Post: # 22455Unread post VFAU
Wed Jan 09, 2013 5:12 am
Water tube nat gas.
Water softener
Blowdown tank
Water treatment solenoid dosing pumps
Spirax PRVs
Post: # 22457Unread post mossboss
Wed Jan 09, 2013 11:38 am
How many kg per hour does it do Andy
It is easier for people when they know steam delivery qty
It should be on the plate
As a rule about 2.2-2.5 kg of steam is required per 12" record according to mould brand and material ie stainless steel moulds due to Lower heat transfer characteristics would require more steam as against carbon steel which has better heat transfer qualities there fore less steam
Mould insulation also makes a difference
On SMT and Leneds there is a 1/2 inch Bakelite insulating member under the moulds
Not on an Alpha so heat losses are greater there fore more steam required I
Any way this may help some one make a decision
"The Vinyl Truth"
VFAU
Steam
Post: # 22461Unread post VFAU
Wed Jan 09, 2013 4:53 pm
Steam @ 440kg/hr
