For Sale : Dub Plate Cutter in UK
- wonkyfunk303
Hi guys and gals,
I bought a vinyl cutting lathe approximately 6 months ago and sadly i dont have the time (or ability) to master the art of cutting, i think i will stick to djing and producing..... leave the cutting to the pros..
So, well basically i have the full set up, lathe, diamond cutter, eq, modified mixer, vacuum, microscope, amp, heat gun, lamps and ive used it about 6 times, even have some blank plates too... ill even throw in the technics 1210 mk5 that i used for it.
I'm located in the south of the uk and buyer collects, and i am asking £3250 for the lot.
PM me if interested
Jamie
PM me if interested
Jamie
Re: vinyl lathe set up for sale
What exactly have you got?
- powerstrip
Re: For Sale : Dub Plate Cutter in UK
sounds like a vinylium, he mentioned a technincs 1200
Could also be a VinylRecorder which also uses a Technics 1200. But, since the seller does call it "Dub Plate Cutter", and the Vinylium's full name is the Vinylium Kingston Dub Plate Cutter, I would say it is a safe bet that this is the Vinylium.
Actually the seller described it as a lathe so I changed the title to accurately reflect what's on offer here.
It pays to be specific when selling something so a bit more information here might help.
Look at the title.... "Dub Plate Cutter in UK"
Correct. As mentioned above, I changed the title from "Lathe For Sale" to "Dub Plate Cutter For Sale'.
Sound fair?
Sound fair?
Ahhhh. My mistake
- wonkyfunk303
I'll post pictures later, sorry been a bit slack as moving house
- joe_caithness
I take it this is the unit that comes with no support if bought second hand?...
cant pm the seller for some reason, anyhow..
hi,
is it a vinylium kingston dubplate cutter or the vinylrecorder t560, by souri?
(if its a t560) is the cutting head a feedback type?
where exactly are you based in the south?
cheers
hi,
cheers
