However, I saved some old radio station gear (supposedly from a San Francisco station) from heading to the dump, and what I am not keeping (a Rek-o-Kut Model V Deluxe 16" transcription turntable and a Gray 108c tonearm) I am offering here first, then heading to ebay. Prices I'm trying to set below ebay pricing, and I am willing to combine shipping. Equipment is located near Santa Cruz, CA, 95060.
1. An RCA Type 73-A Recorder. This predated the 73-B (so my research tells me), and was available in the 1940 RCA Broadcasting Equipment catalog. I couldn't find it in any other catalogs, and it was gone by at least 1948, if not before. This dusty "pro" lathe has got two motors on 78 and 33.33 drive pucks (old GE motors, I can't see the motor plates easily enough to take pictures, but they're beefy...not sure if they're synchronous-hysteresis or not). The motor board mounts are rotted, but everything moves and adjusts as it should, or at least as I think it should (note, I've refurbed a couple of old Rek/Lenco idler drives and belt driven turntables, and have *some* idea of how it should be moving mechanically...but not knowing this, no guarantees!). It comes mounted on its original board, and is damn heavy (north of 200 lbs., easily). Has a suction tube for chip removal (attach your favorite pump!), and a Spencer microscope. The microscope light works
2. A Rek-o-Kut M5 overhead cutting lathe. It's the type without the crank for the in and out grooves, but I don't really know what it means. All the mechanisms move freely, and it comes with a lead screw that's labelled "120 O-I/10-10-8". It was mounted on the Model V, and removed carefully. It's serial 6647M. $325 plus shipping.
3. An RCA MI-4887 cutting head. The top of the line from RCA, in what appears to be nice shape. I don't know how to measure the resistance of one of these, but have a little Radio Shack meter with kΩ on it and will be glad to follow instructions. Has a stylus in it that is sharp enough to draw blood. $450 plus shipping.
4. What I believe to be a very early Presto 1-C cutting head. It's serial "129", and has the funny yellowing plastic inside. No label, but a "6" on the side of the magnet. The holes and screws imply a Presto 1-C, but I will take it under advisement. Again, untested, but if I learn how I'll edit the item. Its stylus is sharper than the RCA, and draws blood more easily.
I have lots of pictures, which I will add in messages below, and catalog PDFs for the Type 73-A if I can figure out how to get them on here. Sorry for being a putz that way.
Thanks for looking!
Bill
