70 v line transformers for sale
mratx
Post: # 38762Unread post mratx
Mon Nov 30, 2015 3:17 pm
I have a bunch of Realistic 70 volt 10 watt transformers that I acquired in a deal , model 32-1031, I needed a couple and ended up getting a box of them from someone for basically the same price as for two. They're NOS, but the cards and plastic enclosures are not in the greatest shape, the plastic is yellowed and separating from the cards, but the transformers are new and in fine shape. They're good for connecting a 500 ohm head to an 8 ohm power amp, as they have a 10 watt tap, but because they're just 10 watt the frequency response drops off below around 50 hz. But they're good for using with lower fidelity heads like old horseshoe types, or for non-critical use. I used mine to set up a couple of interface boxes with multiple connector types that I can use to quickly test heads or amps as needed.
Normally they go for around $10-13 on ebay, if anyone would like one I'm selling them for $5 plus postage.
mratx
Re: 70 v line transformers for sale
Post: # 38767Unread post mratx
Mon Nov 30, 2015 4:43 pm
Here are pics of one of the transformers and the card details.
