WANTED micro spring scale to check cutter head mass
emidisc
Post: # 45026Unread post emidisc
Fri Dec 02, 2016 4:27 am
WANTED
any ideas were I can obtain one in UK preferably
also Coil adhesive/varnish type material again preferably in UK
many thanks
Emidisc
Re: WANTED micro spring scale to check cutter head mass
Post: # 45030Unread post markrob
Fri Dec 02, 2016 9:01 am
Maybe this would work for you:
http://www.micromark.com/digital-pull-meter,9577.html
Micromark is not UK based, but they may ship to you. Also, I assume its not made by them, so you might be able to find the same product re-branded elsewhwere.
Soulbear
Post: # 45031Unread post Soulbear
Fri Dec 02, 2016 12:18 pm
Hi Emidisc,
This will weigh up to 40Kg with an accuracy to 10g if that's close enough??
40Kg x 10g Digital Fishing Hanging Luggage Weight Weighing Hook Pocket Scale
£2.78 Pence each on the Bay
Also for Coil Varnishes look here:- http://www.aev.co.uk/Check out the Site for a list of Distributors
Regards
:wink: :P :D Soulbear
