Rek-O-Kut lead screws
prestok10
Post: # 46552Unread post prestok10
Fri Mar 31, 2017 9:06 pm
Is it possible to obtain a lead screw that will allow me to cut standard groove (not microgroove) for making 78s? The machine is an Imperial.
Voxster1965
Re: Rek-O-Kut lead screws
Post: # 46554Unread post Voxster1965
Fri Mar 31, 2017 11:53 pm
I also need an outside-in lead screw for a K10 - if anyone can help here it would be most appreciated.
prestok10
Post: # 46560Unread post prestok10
Sat Apr 01, 2017 7:37 pm
I have a K-10 but it is missing some of the gears that take the place of lead screws. There should be four in total - one for outside-in standard groove and one for outside-in microgroove and the other two are the same except inside-out. They are normally found stored under the turntable. The one I have is for outside-in standard groove, which is fine because i mostly cut 78s.
EmAtChapterV
Post: # 46581Unread post EmAtChapterV
Mon Apr 03, 2017 3:45 pm
The 12" Rek-O-Kuts came equipped from the factory with 108 lpi outside-in leadscrews; the 16" version was 120 lpi. Other leadscrews for the 12" were 120, 144, 216, 240 and 264 lpi in either direction; for the 16" there were 105, 135, 210, 240 and 270 lpi. There may also have been a 96 lpi screw for the 12 and a 90 lpi screw for the 16 available briefly when they were first introduced.
Finding any of these for sale now is going to be like looking for a needle in a haystack, sadly. Especially the inside-out screws.
