Presto adapter to fit vinyl recorder?
sat159p1
Post: # 51632Unread post sat159p1
Fri Oct 26, 2018 5:48 am
Guys, does anyone here made an adapter to fit Presto style cutting heads (2 screws) to vinyl recording system? I have a 3d printer, but have avsolutely no knowledge about 3D design...
jjwharris
Re: Presto adapter to fit vinyl recorder?
Post: # 51634Unread post jjwharris
Fri Oct 26, 2018 6:35 am
If you post some dimensions I can probably put something together for you.
jesusfwrl
Post: # 51638Unread post jesusfwrl
Fri Oct 26, 2018 9:45 am
I machine these out of aluminum.
Have a look here:http://agnewanalog.com/products/mountingadapter.shtml
I can make one for the VR if you want. I also make stylus shank adapters with which you could fit a Souri stylus on your Presto head:https://agnewanalog.com/blog/2018/10/13/lab-report-making-cutting-stylus-shank-adapters/
