6N Restoration
Lotus503
6N Restoration
Post: # 53981Unread post Lotus503
Sun Aug 25, 2019 11:51 pm
Just wanted to post a few photos of our Presto 6N project. After being out of service for almost 60 years, it's starting to look like a lathe again after removing all the dirt. Made a custom plinth to mount it in, and we're not too far off from running tests to see if it will actually cut a record.
If anyone can point us to where we can find the schematics for a Presto A93 amplifier, we would very much appreciate it. I tried to contact Mr. Graves that has the prestohistory.com website to see if he still carried reprints of the user's manual, but his email doesn't seem to be active.
Thanks for the help!
Re: 6N Restoration
Post: # 53983Unread post piaptk
Mon Aug 26, 2019 8:24 pm
Dont have the schematic, but a piece of advice. DO NOT rest the overhead on the feedscrew!!! Only on the back bar. You can screw up the clutch that ghe feedscrew attaches to (the only piece on the whole lathe that cant be remade relatively easily), and if you rest it on the back bar, you will be able to remove the platter without moving the overhead.
Good luck!
Lotus503
Re: 6N Restoration
Post: # 53984Unread post Lotus503
Mon Aug 26, 2019 11:19 pm
Thanks for pointing that out. It was resting on the back bar, but must have been moved while fitting it to the plinth. We had to take it in and out several times. I think I'll remove the feed screw until we get it completely mounted...
