Looking for center spindle clamp
cheapthrills
Post: # 56788Unread post cheapthrills
Sun Sep 13, 2020 4:44 pm
Looking to clamp down blanks using hex screw. Does anyone have a link or info? Currently using parts from my local hardware store. I've seen a better clamp in your photos. Thanks!
Soulbear
Re: Looking for center spindle clamp
Post: # 56789Unread post Soulbear
Sun Sep 13, 2020 5:06 pm
Hi There,
Something like this??? :wink: :wink: :wink:
https://www.hifix.co.uk/michell-turntable-clamp?gclid=EAIaIQobChMIl_b3uYDn6wIVAs53Ch0ERwPBEAQYBCABEgKbL_D_BwE
Regards Soulbear :P :) :D
cheapthrills
Post: # 56791Unread post cheapthrills
Sun Sep 13, 2020 5:52 pm
Like this with a set screw.
Jccc
Post: # 56792Unread post Jccc
Sun Sep 13, 2020 6:39 pm
cheapthrills
Post: # 56793Unread post cheapthrills
Sun Sep 13, 2020 8:31 pm
Agnew Analog product looks great, but there is no price and no link to buy on the website.
Post: # 56795Unread post Aussie0zborn
Sun Sep 13, 2020 10:05 pm
Why not send an email?
cheapthrills
Post: # 56797Unread post cheapthrills
Mon Sep 14, 2020 1:40 am
Well yes I sent email when I visited the website. My other option would be to tap the center spindle or have it modified (replaced) with a threaded part. Anyone doing this? Its for a sp10.
cheapthrills
Post: # 56798Unread post cheapthrills
Mon Sep 14, 2020 1:53 am
I like SoulBears recommendation, I ordered the Michell clamp but my spindle on the SP10 is too short and the Michell clamp does not grab.
Soulbear
Post: # 56799Unread post Soulbear
Mon Sep 14, 2020 6:28 am
MMmmm now I'm Curious?????? Soulbear was advised by no less than 3 other Bears who ran some Tests and found the Michell Clamp and SP10 Combination to Work Fine!!! :shock: :shock: :shock:
If what you say is true, I must go and have words with these Naughty Bears!!! :roll: :roll: :roll:
Michell Clamp on SP10.MOV
aaron
Post: # 56801Unread post aaron
Mon Sep 14, 2020 9:49 am
I took a metal 45 adapter, tapped it with a set screw. Works great!
cheapthrills
Post: # 56803Unread post cheapthrills
Mon Sep 14, 2020 12:07 pm
Hi Soulbear, if my SP10 was in original condition the Michell Clamp would work great. But as you can see the spindle is cut short.
kcdonahue
Post: # 56821Unread post kcdonahue
Thu Sep 17, 2020 1:21 pm
I'm not sure if you have enough spindle to use the Kab Super Record Grip but I have had good success with it.
https://www.kabusa.com/usagrip.htm
cheapthrills
Post: # 56843Unread post cheapthrills
Sat Sep 19, 2020 7:52 pm
Thank you kcdonahue
Post: # 56846Unread post tragwag
Sun Sep 20, 2020 1:10 pm
the michell clamp is much better than the standard VR clamp, but I can't use it for cutting, it's too tall!
kcdonahue
Post: # 56849Unread post kcdonahue
Sun Sep 20, 2020 8:06 pm
I took two pics of the KAB record clamp and posted them on imgur for clarity. It's clamping mechanism is quite different than the others and it is very light weight. I'm not sure how tall the Mitchel clamp is, but this on is approximately 1 inch tall.
https://imgur.com/gallery/TB38MGP
KC
