Souri Lathe - Noisy cuts
sicky666
Post: # 59065Unread post sicky666
Tue Aug 03, 2021 5:52 am
So I have been having some issues lately.
I have been getting noisy cuts after only x 10 cuts through the machine, lots of surface noise which has never happened before, does seem to be on one side each time and I cant seem to get to the bottom of it.
I have wasted x 4 new styluses doing this. I recalibrate the machine every time, make sure the head/needle is central to the middle of the turntable, making sure the angle is correct and also checking the weights regularly.
I have changed the oil in the dashpot and also cleaned the lead screw.
Is there anything I am missing?
I'm using My shank blanks and I recently purchased a synthetic stylus and the same thing has happened. I have also switched over to Souri blanks just to see if that was the problem and the same problem is happening.
The only thing now is that the head possibly has a problem causing it to damage the stylus.
Any help or input would be greatly appreciated
boryo
Re: Souri Lathe - Noisy cuts
Post: # 59067Unread post boryo
Tue Aug 03, 2021 7:47 am
did you tried without sending any music the head?
sicky666
Post: # 59069Unread post sicky666
Tue Aug 03, 2021 9:56 am
Yep cut a silent groove with the cutting amp switched off, still get the same problem
Post: # 59101Unread post tragwag
Mon Aug 09, 2021 2:13 pm
hows your turntable?
Hedelain
Post: # 59163Unread post Hedelain
Mon Aug 16, 2021 3:21 pm
I have it sometimes in left channel only. Minimizing with recalibration after recalibration.
