12-inch Dinker/Label Punch
- trendkiller
Hello,
Does anyone know where, in the U.S., to get an automatic dinker to punch out labels on 12-inch records? P.M. me, if you prefer. Thank you for your help!
Re: 12-inch Dinker/Label Punch
RPA P-50
https://youtu.be/8qTd72niups https://youtu.be/djVxZDdfSqs
Not the most affordable solution but there you have it.
- trendkiller
Thank you! I wonder how difficult it would be to make one.
Drill press, a hole saw, HSS is good enough, some 105-115mm in diameter and some pull down jig to keep the records in place so they don't fly away.
We had one custom made by a local company, its not automatic but it works with both trimmed and untrimmed records.
https://speedex.com.au/index.php?route=product/category&path=275
- trendkiller
Thank you, both, very much. Wouldn't a saw produce a lot of shavings and dust?
The Speedex is what we're looking for! Being in the U.S. though, shipping would be expensive. I'll look into it. Thank you, again!
i had good luck with this one:trendkiller wrote: ↑Fri Jun 03, 2022 11:55 amThank you, both, very much. Wouldn't a saw produce a lot of shavings and dust?
https://www.wolfcraft.com/products/wolfcraft/en/EUR/Products/Machine-Accessories/Hole-Saws-Annular-Bits/Hole-Saws/Carbon-Steel-Hole-Saws/Carbon-Steel-Hole-Saw%2C-%C3%98-74---127-mm/p/P_5969
Yup.. Dust maybe (it shouldnt), shavings for sure... The hole saw needs to be the kind for cutting plastics anyway, so the shavings will be quite big and clean. You need to do the dirty deed away from the process anyway. The grinder itself will generate a lot more dusty junk anyway.
