Some Help Is Needed With Audacity
Oldskoolhousehead
Post: # 60901Unread post Oldskoolhousehead
Mon Jun 06, 2022 5:55 am
Hello folks. I hope you can me with my issue. A while ago I discovered an web based application for converting sound files to svg graphics. I'm intended to convert my favorite tracks to graphic files, in order to put them on laser engraved records. However, I have a problem: Some of those tracks are available on 33 rpm singles or compilation albums. I spent quite a time with Audacity, but changing the speed of sound files from 33 to 45 rpm won't work. I'll be glad if you give me some advice about it. Thanks in advance,
andyburnout
Re: Some Help Is Needed With Audacity
Post: # 60936Unread post andyburnout
Mon Jun 13, 2022 12:01 am
Surprised no one has jumped on this. I don’t use Audacity all that much my lathe runs slower so I use Reaper to change the speed rate of the audio so once cut it plays back at the required speed. I’d suggest giving it a try.
