VR t-560 cutter head position setting
yano
Post: # 62962Unread post yano
Sun May 28, 2023 3:45 pm
Hi Trolls !
does anyone know how to adjust the cutting head?
which screw can be adjusted to the correct position?
for some reason the head is not parallel to the upper bridge....
I'm trying to show the problem in the picture.
https://kepkuldes.com/image/BwfrnL
boryo
Re: VR t-560 cutter head position setting
Post: # 62964Unread post boryo
Mon May 29, 2023 1:31 am
the black knob that tightens the head to the suspension. if you watch carefully when you put the head and turn the knob the head turns a bit to the right, probably because of the spinning nut inside the hole.
best,
bob
yano
Post: # 62965Unread post yano
Mon May 29, 2023 3:39 am
best,
bob
the error is not there.
the suspension is also slanted..
boryo
Post: # 62966Unread post boryo
Mon May 29, 2023 5:09 am
i think it will be best if you post actual photo taken from the top of the machine
PMST
Post: # 62970Unread post PMST
Tue May 30, 2023 6:48 am
Is the overhead definitely straight? The head carriage travels along the feedscrew, that angle can’t change, only the swing left to right or up and down. If the full head travel angle is off I’d adjust the overhead (assuming ive understood your image correctly, maybe I haven’t.....)
Dub Studio
Post: # 63000Unread post Dub Studio
Sun Jun 04, 2023 7:03 pm
There are two bolts on the underside of the suspension assembly that run up into the brass nut of the leadsrew. You can undo them slightly and adjust the position of the assembly there.
yano
Post: # 63002Unread post yano
Mon Jun 05, 2023 5:54 am
Thanks ! this was the right solution :)
