I found some old threads about DIY advance balls, I think markrob said he tried a glass bead, and someone else tried a bearing.
Has anyone had any luck with this? I'm trying to find a good solution for this, because using a diamond with makrolon blanks and no vacuum hold-down is getting a bit hard. The blanks are never perfectly flat, and I find that the really bad ones have a groove depth that varies. Just seeing if anyone has had a good DIY solution for this. I'm using a Presto 1C on a DIY lathe.
DIY advance balls (again)
- Fela Borbone
Re: DIY advance balls (again)
Hello!
Maybe extracting the rigth bearing from an scratch precision machine (Hard disc drve, video head,etc)
I wonder how the advance balls are lubricated, and protected from outside products.
I had no luck with the above, but I read somewhere about a lathe with an skate instead of ball. It was covered with a cloth or alike tho minimise friction noises.
The manufactured advance balls work way better. Get a real one if you can find it.
