Weird channel drop out on low input signal
David34
Post: # 54560Unread post David34
Tue Dec 03, 2019 4:55 pm
Hey trollsters!
I'm experiencing a weird issue on my VR.
When cutting, and through quiet parts, the audio is dropping level on one (right) channel. However, when the loud parts come in, the channel comes back to stereo..??
Has anyone experienced this? I did think it was my pick up needle while I am monitoring, but have checked several pick up needles.
I am going to try and calibrate everything, but if anyone has experienced this before, or has any suggestions, I will grateful!
Thanks in advance!
Radardoug
Re: Weird channel drop out on low input signal
Post: # 54561Unread post Radardoug
Tue Dec 03, 2019 5:19 pm
Thats a standard fault for an intermittent connection. Once you get enough voltage across it, it breaks over and starts working.
You have to trace through your devices to find where the faulty connection is.
MEGAMIKE
Post: # 54563Unread post MEGAMIKE
Tue Dec 03, 2019 11:33 pm
right on radar. :D ..i found my problem in the right channel in my mixer ,just cleaned it up with IPA and it went away...assuming u still have the mixer?..
okpanda
Post: # 54565Unread post okpanda
Wed Dec 04, 2019 11:17 am
have you checked your cutterhead amplifier?
okpanda
Post: # 54566Unread post okpanda
Wed Dec 04, 2019 11:39 am
can you hear the volume drop in the transducers on your cutterhead? if so, the problem is somewhere before that in your chain.
Jesus H Chrysler
Post: # 54570Unread post Jesus H Chrysler
Wed Dec 04, 2019 8:19 pm
Check the inline fuseholders. Make sure the little set screws are tight on the wires. That was the culprit when I had that problem.
David34
Post: # 54571Unread post David34
Thu Dec 05, 2019 4:50 am
WOW..Thanks for all the tips you legends!
ps: What is IPA ?? (Indian Pale Ale? haha!!)
Yes I am using the shitty mixer. Don't want to really..
MEGAMIKE
Post: # 54572Unread post MEGAMIKE
Thu Dec 05, 2019 5:04 am
isolpropal acid...and the shity mixer is good 13years mine is still going :)
MEGAMIKE
Post: # 54573Unread post MEGAMIKE
Thu Dec 05, 2019 5:29 am
sorry isopropyl alcohol
David34
Post: # 54576Unread post David34
Thu Dec 05, 2019 3:50 pm
Spray it in vertical fader? Or on connections? Or all..
My in line fuse screws were loose!!! Tight now!
Thanks for all the help
David34
Post: # 54579Unread post David34
Thu Dec 05, 2019 5:21 pm
Ok so I’ve tightened those 2 wires with the fuses and still have the issue. Haven’t sprayed the fader with IPA yet, not sure what to do there. But I did move fader up and down, seems fine to me..
MEGAMIKE
Post: # 54580Unread post MEGAMIKE
Thu Dec 05, 2019 11:58 pm
my audio cutting out was the same problem i had years ago as a dj..i would spray it out with ub40..when it did the same on my vr mixer i took the face plate off and sprayed ipa in the vertical right fader and it went away.it came back and i did it again mind you my studio is in a hot/dusty ozzy backyard shed..try installing another mixer and trace the problem back to the units etc...my vr mixer only has that one fader used so thats why it has lasted a long time ,my dj mixers all 12 of them that i still have are all destroyed, faders cooked..
MEGAMIKE
Post: # 54581Unread post MEGAMIKE
Thu Dec 05, 2019 11:59 pm
ub40 hahahahahaha i meant to say wd40...
David34
Post: # 54582Unread post David34
Fri Dec 06, 2019 12:00 am
It’s gone!
Intermittent.
I played around w a few rca etc etc., swapped channels, sprayed ISO. It went, came back, now it’s gone after 6 cuts..
Love my job though!
Thanks all!!
Post: # 54613Unread post tragwag
Mon Dec 09, 2019 4:49 pm
Jesus H Chrysler wrote:Check the inline fuseholders. Make sure the little set screws are tight on the wires. That was the culprit when I had that problem.
this was my problem more than once as well!
Discomo
Post: # 54644Unread post Discomo
Wed Dec 11, 2019 9:17 pm
Interestingly, I had the same exact problem recently. Apparently one of the two din connectors at the cuttinghead wasn’t fitting tightly anymore. I find the Din-connectors on the VR a very weak spot. Had previously problems with din connectors at the back of the VR, which lead to the decease of the motor. So, I wonder, isn’t there a better solution for these connectors? Why not BNC plugs?
handcut
Post: # 54654Unread post handcut
Thu Dec 12, 2019 6:21 am
I replaced mine with Re'an DIN plugs. Gold plated pins, metal shell and a much nicer fit...
