testing Jerry's steel cone styli
uvoscillator
Post: # 27810Unread post uvoscillator
Wed Nov 20, 2013 1:21 pm
Hi there !
Just receive and done first testing Jerry's steel styli.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=281196676466
I've take cone ones and try to emboss with them. With comparing to sapphire.
Anything was done as usual - WD-40 for lubricating, 60-70C heating with lamp.
Jerry's cone:
https://dl.dropboxusercontent.com/u/1235999/steelstylitest/saph_test.wav
Sapphire:
https://dl.dropboxusercontent.com/u/1235999/steelstylitest/steel_test.wav
I've experimented with steel before and Jerry's styli works very good for steel, but as you can see sapphire is out of competition.
Can't say how much they will last. This needs to do different research :)
Good luck !
Sergey
Best !
morrisjer
Re: testing Jerry's steel cone styli
Post: # 27812Unread post morrisjer
Wed Nov 20, 2013 1:41 pm
Hey Sergey,
Thanks for your response to my steel needles. I am constantly experimenting with my steel, and I continue to improve by making them smoother around the tip and the right cone angle all through. It sounds like you have had good results with my needles, but you seem to lean towards sapphire if I read your post correctly. I am sure sapphire costs more than my needles, and I have no idea how long they would last. I have a PR man, Mike, that is a Lathetroll member and I am always sending needles to him to test with his many lathes. Then he replies to me telling me the good and weak points. Eventually as we work together, hopefully we can zero in and eliminate some of any flaws that there may be.
Jerry :)
morrisjer
Post: # 27816Unread post morrisjer
Wed Nov 20, 2013 4:09 pm
About my needles. A member of Lathetrolls provided the following:
"Did he order the triangles? Sapphires do, and always will, blow anybody's steel needles out of the water. You aren't providing a substitute for $100 sapphires.. you are providing a LOW COST alternative for people to experiment with. You are a bicycle, Sapphires are a Mercedes... Not fair to compare yourself to something you aren't trying to be anyway."
Post: # 27819Unread post piaptk
Wed Nov 20, 2013 6:44 pm
I wrote that, I thought he was using the steel triangles for CUTTING.
In theory, Jerry's cones should be comparable to a backwards styli. However, we have been doing a LOT of adjustments, and trying to find just the right cone. Some have been better than others. Not sure which batch you got, Sergei, but I'd be interested to know how the sound was... email me at lathecuts-AAAT-yahoooooo-dawt-cawm... Any feedback you can give us will help us dial this thing in! Jerry keeps pretty good notes about what he does to each batch, and I'm guessing what batch he sends everyone, so if there is a problem with yours, we will know which batch, what he did, and we can fix it.
Gus
Post: # 28037Unread post Gus
Fri Dec 06, 2013 9:41 pm
hey uvoscillator nice sound!
what format do you use for embossing?
uvoscillator wrote:Hi there !
Jerry's cone:
Sapphire:
Good luck !
Sergey
Post: # 28038Unread post opcode66
Fri Dec 06, 2013 11:24 pm
Those grooves look nice! Promising.
uvoscillator
Post: # 28039Unread post uvoscillator
Sat Dec 07, 2013 6:04 am
Gus wrote:hey uvoscillator nice sound!
thanks ! here sounds a bit overmodulated
what do you mean 'format' ?
I can emboss all sizes, just expected how to heat big ones with hot water ))
Best !
Gus
Post: # 28040Unread post Gus
Sat Dec 07, 2013 7:23 am
sorry for my bad english
i mean what material do you use for embossing
uvoscillator
Post: # 28041Unread post uvoscillator
Sat Dec 07, 2013 9:38 am
Gus wrote:sorry for my bad english
no problem, for me is also not native language ))
I'm embossing polycarbonate, check this forum about it, here is a lot of information
about it
Best !
Post: # 28575Unread post piaptk
Sat Jan 18, 2014 3:15 pm
When I get back to Tucson, I will send some pics of the grooves I'm cutting with Jerry's cones... they look and sound really good. His current batch is really top notch when combines with lighter fluid.
uvoscillator
Post: # 28576Unread post uvoscillator
Sat Jan 18, 2014 3:23 pm
need to try again than ! and what about horns ? that is my main problem when embossing (
Best !
morrisjer
Post: # 28577Unread post morrisjer
Sat Jan 18, 2014 3:38 pm
opcode66 wrote:Those grooves look nice! Promising.
I have made some improvements since my first batch of cone needles in steel. They are more smooth, and since my PR man, Mike, has been using lighter fluid (Ronsonol in the yellow bottle) to prep the polycarbonate discs that removes gunk from the peel away plastic, he has been getting some very good cuts with my cones. He sent me a disc of some music he cut with my needles and it sounded very good.
Jerry
Post: # 28665Unread post tragwag
Tue Jan 21, 2014 2:48 pm
uvoscillator wrote:need to try again than ! and what about horns ? that is my main problem when embossing (
I have not tested Jerry's styli yet (though I will soon), but I'm thinking you need more heat on the blank.
do you use a heat lamp?
uvoscillator
Post: # 28669Unread post uvoscillator
Tue Jan 21, 2014 2:58 pm
yep, sure! start when blank around 65C
as far I can understand heat and pressure is important in embossing, but also this two factors gives horns too.
I'm embossing with backward sapphires with about 90 degrees angle, sounds perfect, but horns...
Best !
stanislav
Post: # 28674Unread post stanislav
Tue Jan 21, 2014 3:15 pm
There will always be at discharge, but you harder than when cutting a groove, you can convert a 20 micron square times the pressure of the knife on this micro surface, times the surface of the disc, comes more than 100 tonnes on 12-inch plate :)
Post: # 28741Unread post piaptk
Sat Jan 25, 2014 8:25 pm
Horns are unavoidable with embossing. If you don't want horns, you've got to cut and remove chip with a vacuum... When the material leaves the groove, it's gotta go somewhere... either up the vacuum or up to the side of the groove.
I took a record I embossed with Jerry's needles to Len Horowitz yesterday. He was blown away by the fidelity and low noise floor. However, he noticed missing highs. So he looks at the groove and said "looks more like a standard groove than a microgroove, by the shape of it". So he put a standard stylus in his cartridge and voila... here came all the highs and it sounded incredible. The highs were there, some of them just weren't able to be played by the micro stylus.
So, Jerry and I are now working to figure out how to get a stylus that cuts a groove that is closer to a microgroove.
Of course, each cut with each needle is a little different. This particular recorder was darker than many that I had cut, so the needle could have been worn down more after hours and hours of use.
Even with the limitations of the current batch, they are still an incredible bargain and will get the amateur hobbyist wanting to play with plastic much easier and consistent results than even a turned around sapphire stylus.
uvoscillator
Post: # 28743Unread post uvoscillator
Sun Jan 26, 2014 12:35 am
I wish I can meet Len just to have talk :o
Yes, I also noticed, that not all playback needles plays good.
Thanks for keep us updated!
Best !
Post: # 28889Unread post tragwag
Mon Feb 10, 2014 12:39 pm
I just want to add my two cents to this discussion.
I've been embossing on poly for over a year now, making lathe cut records.
I used Jerry's embossing cones for the first time this past week, and they've performed very well.
As you can see from the above posts, the groove geometry is right on.
I found the tracking, groove depth, and source volume very easy to set.
These cones are, if I had to quantify it, probably 90% as good as a sapphire for embossing in terms of sound quality, groove geometry, and ease of use. I have not tested the longevity yet.
The best part is, they are readily available, and super affordable.
I commend Jerry for taking this on, and providing a great product that virtually anyone can purchase.
(Let it be known that I have no professional affiliation with Jerry, I bought these styli on ebay for $10, like anyone else)
Lima Victor
Post: # 30089Unread post Lima Victor
Wed May 14, 2014 8:51 am
I'm considering buying one of these stylii (can be found at http://www.ebay.com/itm/Record-lathe-cutter-presto-record-in-stylus-needle-styli-rek-o-kut-recorder-/281255271864?pt=LH_DefaultDomain_0&hash=item417c1eddb8 )
But i'm doubting which one to choose. Of course, i could try it out, but i'm a poor college student so if i can save $10 i will ;)
Can the cone be used for both polyacrilate and acetate sheets? The local arts & crafts store has fairly thick acetate sheets for cheap, those are much easier to obtain than polyacrilate disks in my area. However, polyacrilate is a tried and tested material and gives nicer looking results.
I'd like to experiment with both materials, but i'm building a cutting head myself and the stylus will be permanently mounted in it. So i have to settle on one stylus. Could the embossing cone also be used for the acetate sheets? Those sheets look like overhead projection sheets but slightly thicker - a bit like the base of photographic film, without the light sensitive coating.
budharpey
Post: # 30156Unread post budharpey
Sun May 18, 2014 9:12 pm
Hi, since you will be embossing/engraving the cone will be either way the only choice. The other two types, the triangular ones, are for cutting. I haven't tried acetat sheets by myself so far because I don't know where to buy them near me, but I guess the cone will suit as well.
