New Colours + Dashpot + Suction Pump
New Colours
We are excited to announce another 6 colours for 7/10/12” lathe-cuts. This brings the total to 28!
Dashpot (VR T-560 only)
My Shank have introduced an upgraded dashpot for VR users. This understated component serves a very critical function and this upgrade is significant:
I assume you all have access to the My Shank blog article which goes into more detail.Enhanced Stability – Cleaner Cuts
Upgrade your VinylRecorder with this custom-engineered dashpot, designed to dramatically improve cutting stability and groove precision. By absorbing unwanted vertical vibrations, it ensures smoother tracking, cleaner modulation, and a noticeably quieter groove, even at higher volumes.
Robust and Precision-Engineered
Made from durable, high-quality 3D-printed components, this dashpot is lightweight yet solid. It features a precision-calibrated fluid piston for finely adjustable damping, allowing you to perfectly adapt it to your cutting head’s characteristics.
Professional Cutting Results
By minimizing mechanical feedback and stylus bounce, this dashpot enhances groove accuracy, improves signal-to-noise ratio, and supports more stable vertical modulation—especially critical when cutting bass-heavy or complex material.
Plug-and-Play Compatibility
Designed specifically for VinylRecorder arms, it installs in minutes without any modifications. Ideal for both home setups and professional vinyl mastering workflows.
Made for Dubplate and Master Cutting
Whether you’re cutting acetates, dubplates, or master discs, this dashpot is a simple but powerful upgrade that brings greater control and cleaner results to your cutting process.
Suction Pump
Small, powerful and quiet. What’s not to like? Available in Blue and White (random, no choice)
Noise: 38db
64W
12” for scale:
For more info: Distribution for UK lathe-cutters and enquiries: blanks@bladudflies.com
Michael
